Huawei modem universal flasher http://www.francesco-pompili.it/images/stories/h2.png HOW WORKS: 1)Select huawei update wizard exe from Select Firmware-Extract from EXE and wait that program find fimrware's file 1a)If you have already done step 1 , can load files from Select Firmware-Parse from HMF 2)Select firmware** related to your board* 4)Select Flash Modem-Normal Flash and wait 4a)If your modem it's half died (stay always on download mode) select Flash Modem-Resurrect Flash *During flash program check compatibility between modem and firmware , if it fails it ask what you want do to...continue or stop flash. **Flash always all files if you dont have any jtag Program works only if pc is connected to internet Program is release as is , without any kind of warranty I have tested it with: e367-s2 e353-s 173-s2 e1550 Download:HERE |
sound great , thanks . im gonna try it |
educational purposes Quote:
I am working on the same script/project (educational purposes) lem me call it Huawei modem flasher. I have been continuously working on this project for more than a year now, I have tried to use sniffer for serial communication with Huawei update wizard as much as possible. Just to learn the update progress. And came to find out that the firmware is all check sum’ed. ‘Im new to crc (check sum) I like to enjoy leaning in VB.net, but as this is a beginners project Please help me by contributing just part of the source code to improve my project. |
absolutly no it'a a trial version so when i want i stop it nonody force tonuse it , if you wont trust to me simply not use it Sent from my iPhone using Tapatalk |
because if we not have flash file the how we can flash?? |
Sorry but this program van flash only firmware extracted from update files Inviato dal mio GT-P7500 usando Tapatalk |
Hallo. How to read NVram of Huawei E353 modem? |
Flashing the Huawei E353Ws-1 This flasher is unable to detect Huawei E353Ws-1 with the new (22) firmware. With this firmware the modem shows up as a network device, not a serial one (no COM port). |
Has anyone tested this software with any other models ? Please mention here ... |
you have a dead modem with you, then why wait for others reply. just try and post result here...... |
Doesn't work for E392. Application interface port is present and functional, e.g. is able to comunicate with QPST and RevSkills. But no port is detected by fr3nsis's flasher. Is it possible to fix? |
I will check Which is the name of huawei com ports? |
E353Ws-1 with the new (22) firmware. Original firmware needed urjent. |
1 Attachment(s) Hallo. How are you fr3nsis ? I use your great software Huawei Flasher but now it doesn't work. I have version 1.1I would like to unbrick 1 Huawei dongle. Could you share working Huawei flasher? thank you |
