GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
03-03-2019, 21:32 | #46 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | (if you used unpatched loader or older BALONG downloader.) Procedure is similar for E5573 and E5577, loaders are not the same. - downgrade, display becomes white - read hash, calculate unlock codes - upgrade dashboard, upgrade firmware - enter unlock codes or .. if you used unpatched loader and erased nvram, - on older firmware, fix imei + sn - upgrade dashboard - upgrade firmware - connect modem to pc, fix SSID + wpa password b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
03-15-2019, 10:38 | #47 (permalink) | |
Crazy Poster Join Date: Mar 2015
Member: 2363010 Status: Offline Thanks Meter: 1 | Quote:
The Following User Says Thank You to pkmanii For This Useful Post: |
03-26-2019, 01:23 | #48 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote:
Don't put wrong firmware (wrong model/sub-model). b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
04-24-2019, 16:35 | #50 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2492039 Status: Offline Thanks Meter: 0 | [QUOTE=samsamsolutions;13513045]HI DEAR IT IS 100 PERCENT WORKING MY FILE. NO NEED PAY TO ANY PEROSN FOR FILE UNLOCK AND ENJOY My pc running win 10 u r exe file came pop up then came out which operating system is best of this type file running |
08-16-2020, 18:47 | #51 (permalink) |
Crazy Poster Join Date: Dec 2016 Location: Pakistan Age: 28
Member: 2661546 Status: Offline Thanks Meter: 9 | Good that solution for these devices is possible and free these days, when i joined here i had to dig 100 forums (literally) to get my old zong mifi working again (the notorious 21.318 version). keep it up sam ! |
08-16-2020, 18:59 | #52 (permalink) |
Member: 2661546 Status: Offline Thanks Meter: 9 | (to Brka : Dear, using unpatched bootloader and erasing nvram and then upgrading to to a universal firmware caused modem to be dead (even when model and firmware was correct, that problem was notorious in the 21.318 version of zong devices, we found out that replacing parts of zong firmware with universal one caused the device to get unlocked + function-able) also, reflashing zong firmware even after nv erase caused device to get locked again. |
08-18-2020, 01:15 | #53 (permalink) | |
so that was what i tried on older FW version. No idea about newer ones. No such devices here anyway. b.r. Alex
09-05-2020, 08:21 | #56 (permalink) |
Junior Member Join Date: Aug 2020 Location: N/A
Member: 2965921 Status: Offline Thanks Meter: 1 | I need new usbloader for E8372h-608 (21.327.62.00.1460). Modem stuck in usb mode after Boot Point short. Only Showing one Com Port: (HUAWEI Mobile Connect - 3G PC UI Interface) I have tried all available usbloaders for E8372h but no success yet. This modem is secuboot=1 and with efuse. That's why no older usbloader is working on it. Only new usbloader or some patched usbloader will work on it. Please help, if someone can.. Thanks & Regards.! |
03-04-2021, 00:09 | #58 (permalink) |
Junior Member Join Date: Feb 2017 Location: benin
Member: 2687258 Status: Offline Thanks Meter: 0 | Hello Please re-send file, drive remove it is detect like virus. Need this file or how to unlock Found moderm : E5573cs-322 Model : Huawei E5573 (untested) IMEI : 860390046146274 Serial NR : DGF7S1964004864 Firmware : 21.329.63.00.679 Dashboard version : WEBUI_17.100.20.01.679_MRES Web UI version : WEBUI_17.100.20.01.679_MRES Sim lock status : lock (card lock) Wrong code entered : 0 (unlock code attenpts left : 10) |
