GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
03-27-2019, 11:00 | #1 (permalink) |
Freak Poster Join Date: May 2015 Location: Pakistan
Member: 2401943 Status: Offline Thanks Meter: 182 | E5573Cs-322 Model : Huawei AuthVer 4 modem (New) IMEI : 86XXXXXXXXXXXXX Serial NR. : 0123456789ABCDEF Firmware : 21.318.03.00.00 Compile date / time : May 25 2016 17:14:01 Hardware ver. : CL1E5573CSM11 Ver.B Dashboard version : WEBUI_17.100.08.01.1279 Web UI version : WEBUI_17.100.08.01.1279_MRE5 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) i need help to reset admin pass, i try all tricks, but not work. Incorrect user name or password. Please try again. AT^WIKEY=0,"11223344" |
03-29-2019, 18:37 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,797 | you erased nvram by wrong downgrade/bad flash/loader. to fix it ... - downgrade - fix imei, sn, etc. - upgrade dashboard - upgrade firmware - connect, install drivers - via web browser login, set all b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
03-31-2019, 22:39 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,797 | you have the info already. google is your friend. b.r. Alex
04-03-2019, 11:11 | #9 (permalink) | |
Junior Member Join Date: Nov 2017
Member: 2782064 Status: Offline Thanks Meter: 3 | Quote:
