GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
04-14-2019, 07:46 | #1 (permalink) |
Junior Member Join Date: Jan 2019 Location: Nawabshah
Member: 2888365 Status: Offline Thanks Meter: 47 | E5573Cs-322 how to unkock??????????? Found modem : E5573Cs-322 Model : Huawei AuthVer 4 modem (New) IMEI : 860000000000009 Serial NR. : DGF7S18C07006426 Firmware : 21.333.64.00.1456 Dashboard version : WEBUI_17.100.20.01.306_MRE5 Web UI version : WEBUI_17.100.20.01.306_MRE5 SIM Lock status : Locked (Card Lock) Wrong codes entered : 0 (unlock attempts left : 10) |
The Following User Says Thank You to Iftikhar-Ahmed For This Useful Post: |
04-14-2019, 08:06 | #2 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Before create a post just use the search button, Already has been discussion & solution above your same issue here, http://forum.gsmhosting.com/vbb/13611923-post3.html I Strongly recommended to you, try with this firmware, hopefully your device should unlocked.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
04-18-2019, 11:19 | #3 (permalink) | |
Crazy Poster Join Date: Feb 2018 Location: Sheikhupura Pakistan
Member: 2812460 Status: Offline Thanks Meter: 11 | e5573cs-322 imei repair Quote:
how can i fix this issue???? | |
