07-04-2018, 20:18 | #1 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2102145 Status: Offline Thanks Meter: 10 | error remove frp altice s70 Selected model: MT6755 Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM14) Boot mode: Preloader Phone detected...Please wait Using Algo 3. Helio MT6755 phone detected, swithing to helio api Helio connect da error, aborting. BBCHIP MT6755 [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware Boot Fail.!!!. All done. |
07-07-2018, 21:47 | #2 (permalink) |
Member: 2102145 Status: Offline Thanks Meter: 10 | Is there any solution to bypass frp. (bootloader) partition-size protect2: c78000 (bootloader) partition-type protect2: ext4 (bootloader) partition-size protect1: 800000 (bootloader) partition-type protect1: ext4 (bootloader) partition-size:nvram: 500000 (bootloader) partition-type:nvram: raw data (bootloader) partition-size proinfo: 300000 (bootloader) partition-type proinfo: raw data (bootloader) partition-size preloader: 40000 (bootloader) partition-type preloader: raw data (bootloader) off-mode-charge: 1 (bootloader) warranty: yes (bootloader) unlocked: no (bootloader) secure: yes (bootloader) kernel: lk (bootloader) product: SR6750_65_N (bootloader) version-preloader: (bootloader) version: 0.5 all: Done!! finished. total time: 0.016s |
07-08-2018, 07:37 | #6 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | It means, you need to pick Auth or DA (Download Agent) from its official firmware. If found, choose these files correctly from exe custom loader. In this way, you can do frp |
07-13-2019, 18:07 | #8 (permalink) |
Freak Poster Join Date: Nov 2008 Location: uganda Age: 50
Member: 894224 Status: Offline Thanks Meter: 96 | Selected Model: 0-By CPU: ELBRUS Exe version: NCKBox AndroidMTK 2.0 Scenario: [0]Safe Flash Will be used loader: MTK_AllInOne_DA_SP.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM14) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6757 1 cb00 Using Algo 3. Helio MT6757 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE Helio connect da error, aborting. Error[0xc0030003]: STATUS_DA_SELECTION_ERR BBCHIP MT6757 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. infinix hot 7 x625c bricked and cant flash |
07-13-2019, 18:35 | #9 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Quote:
u can select starnaute 4 | |
