02-26-2021, 10:32 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | brom mode in mtk phones meen vid = 0e8d and pid=0003 . You must learn basics about mtk phones if you want to service this phones. |
The Following User Says Thank You to orbita For This Useful Post: |
02-26-2021, 14:36 | #4 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
preloder mode(when run preloader) To put phone in this mode, mostly need simple insert usb cable without press any key. brom mode, to put phone in this mode, need to press vol buttons when exe ask. If you will boot phone in brom mode or preloader mode, is used same driver, not need special driver for this. In brom mode is used built in cpu small loader to boot phone and not deppend from flash. You can boot phone in brom mode, even with desoldered flash ic. When you make testpoint, is little different thing, it's called emergenty boot mode and phone skip some security check. | |
02-27-2021, 03:51 | #6 (permalink) | |
Flash mode driver is same, like for other models, if you serviced any mtk phone before, you have already installed driver. If you want to use skip auth function, to service phone in flash mode, you must install only filter for libusb. | |
