06-25-2020, 16:10 | #1 (permalink) | |
Freak Poster Join Date: Mar 2014 Location: Earth
Member: 2156783 Status: Offline Thanks Meter: 95 | HELP: ERROR auth file CRO-L22 [ANSWERED] but i get this error Quote:
06-25-2020, 16:45 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | You must connect phone without pressing any key(in preloader mode, not brom). If phone have erased preloader, it's not supported. |
The Following User Says Thank You to orbita For This Useful Post: |
06-25-2020, 16:57 | #3 (permalink) | |
Member: 2156783 Status: Offline Thanks Meter: 95 | its boot in preloader now i will charge battery and try again phone problem is (Your Device Has Failed Verification And May Not Work Properly) Your Device Will Boot In 5 Seconds " Quote:
06-26-2020, 15:58 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Many phones with this error usually have damaged or desoldered flash ic or water damaged hardware. Try to disasemble phone and check. Also you can check debug log, to see what exactly create this problem. Last edited by orbita; 06-26-2020 at 16:04. |
