Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 10-19-2021, 13:47   #1 (permalink)
Member: 2938458
Thanks Meter: 59
Help!! Nck android mtk 2.9.7 error [ANSWERED]
Action : Boot Info.
Selected 0-By CPU:ELBRUS
Exe version: NCKBox AndroidMTK 2.9.7
Phone must be off with battery inside.
Battery must be charged
Please connect phone in brom mode
For some phones need to keep "VOL-" button untill inserting USB cable.
For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable.
For some phones need to keep "VOL+" button untill inserting USB cable.
Detected(8) : MediaTek USB Port (COM8)
[8] \\?\usb#vid_0e8d&pid_0003#5&de3b74c&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
CPU: MT6580 CPU code: 6580 Target config: 7
Secure boot enabled: true
Need serial link authorization: true
Need download agent authorization: true
SWJTAG enabled: true
EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false
Root cert required: false
Memory read authorization: false
Memory write authorization: false
Cmd 0xC8 blocked: false
Executing exploit, do not disconnect phone
then the software close. was working fine on previous version
Old 10-19-2021, 14:40   #2 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Thanks or report, will check it.
Will be very usefull if you will post details about phone also.
Old 10-19-2021, 19:06   #3 (permalink)
Member: 2938458
Thanks Meter: 59
any phone i choose bypass security option does that. version 2.9.6 works fine though
Old 10-19-2021, 21:11   #4 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Problem already fixed, this night or tomorow installers will be reuploaded.
The Following 3 Users Say Thank You to orbita For This Useful Post:
Old 10-20-2021, 13:03   #5 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
You can download from support, using main module installer with fixed version.
The Following 2 Users Say Thank You to orbita For This Useful Post:
Old 10-20-2021, 15:11   #6 (permalink)
Member: 2938458
Thanks Meter: 59
will test and give feedback right away
Old 10-20-2021, 15:22   #7 (permalink)
Member: 2938458
Thanks Meter: 59
Action : Boot Info.
CPU: MT6761 CPU code: 717 Target config: e5
Need serial link authorization: false
Memory read authorization: true
Memory write authorization: true
Cmd 0xC8 blocked: true
Exploit has been executed successfully.
[38800]Dumping phone preloader.
Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader _backup\preloader_x657b_h6117.bin
Waiting for handle to become active......
Reseived active handle repply from phone......
Booting phone
Boot mode: Brom
Phone detected...Please wait
BBCHIP: 6761 200 ca01
Using Algo 1.
Helio MT6761 phone detected, swithing to helio api
Helio enabled DRAM in First Da: FALSE
Sending loader.....
BBCHIP MT6761
[1]Storage EMMC
Block size: 512
EMMC FW VERSION: 00:00:00:00:00:00:00:00
EMMC CID: 70010044323630 : 000000000000000000
EMMC UA SIZE: 0x750000000
BOOT STYLE: EMMC BOOT
FULL LENGTH: 0x750c00000 [29.262 GB]
Build Date: Thu Apr 9 11:22:17 CST 2020
Build ID: QP1A.190711.020
Version: 10
Mediatek Version Release: 10
Brand: Infinix
Device: Infinix-X657B
Manufacturer: INFINIX MOBILITY LIMITED
Model: Infinix X657B
This phone have FRP partition.
Phone have OTP partition.
Modem version: MOLY.LR12A.R3.MP.V105.4.P1
[helio]Wait untill phone will start charging.
[0]All done.
Page generated in 0.21508 seconds with 9 queries
