02-03-2013, 13:45 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,260 | [HELP] NCK BOX / Dongle Premium v2 HELP How to USE/UNLOCK/Flash/Install - Info & PDF 1.1.If drivers installed skip step 2. 2. Power on phone complete and install drivers, must be mounted volume with phone drivers, so install from this volume. If custom recovery already flashed go to step 9. 3. Put phone in FastBoot mode holding Vol- and power On(5-10sec) 4. Put usb cable and wait until install drivers(check in device manager if all ok). 5. Open nckbox.exe, select Fastboot_utils tab. 6. Tick flash phone in recovery utils. 7. Click on load and send and select recovery image. 8. Wait until finish, remove cable, remove battery(for 5...6 sec, if not phone will auto power on). 9. put battery, keep Vol+ and power on until phone power in recovery mode. 10. Go to Huawei android tab, select correct model and press check. 11. If all ok press unlock. PS Unlock need make from recovery mode. Last edited by Fast Unlocking; 06-19-2023 at 11:19. |
The Following 7 Users Say Thank You to Fast Unlocking For This Useful Post: |
02-03-2013, 13:50 | #2 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,260 | [FAQ] XPERIA Unlocking Help Info How to Install Drivers for NON Test Point Models: 1. Go to X10 DRIVERS 2. Select the correct 32 bit or 64 bit shortcut folder for your Operating System 3. First run "SEMC Flash Driver Install" 4. Complete the install wizard that appears 5. Second run "ADB Driver Install" 6. Complete the install wizard that appears 7. Next we need to connect the X10 in Flash Mode (some times called boot mode) 8. Remove the battery for 10 seconds and replace 9. With the phone still powered off, Press & HOLD the "Back Button" 10. Still holding the Back Button connect the USB cable 11. Windows will now detect the new hardware and automatically install the drivers. 12. Once complete, remove the USB cable from the phone and power the phone on. 13. Next we will connect the phone with "USB Debugging" Enabled 14. On the phone go to "Settings" 15. Next go to "Applications" 16. Next go to "Development" 17. Now enable "USB Debugging" 18. Click "OK" to confirm enabling of USB Debugging 19. Now connect the USB cable 20. Windows will now detect the new hardware and automatically install the drivers. 21. Once complete you can proceed to unlock your X10, X8 etc... Follow Instructions on Screen. Now we can proceed to Unlocking the X10, X8, etc... 1. Now click on the "SE" tab of the software 2. Please make sure SIM card is removed from the phone Please make sure SD card is inserted in the phone before unlock !!!!!!!! 3. Make sure that your phone is running a later version of ANDROID that 1.6 (tick the box to confirm on the Unlock Client) or .... 4. If you are unsure if your phone is running v2.1 or later, then connect the phone in USB Debugging Mode & click "Check Phone" 5. Ok, we now know we are running ANDROID 2.1 or above (if you are not then please upgrade your phone and start again) 6. Remove your phones battery for 10 seconds and replace 7. Press and HOLD the phones back button 8. While still holding the phones back button connect the USB cable. 9. The unlock client will now start the unlock process 10. When prompted by the UNLOCK SOFTWARE, remove the USB cable and power on the phone. 11. Make sure the phone is in USB Debugging Mode and connect the USB Cable again 12. The SOFTWARE will now complete the unlock Please make sure: Warning! Please make sure SIM card is removed from the phone Please make sure SD card is inserted in the phone before unlock !!!!!!!! Your X10i is NOT running ANDROID V1.6 (please update your phone if it is before unlocking, do not attempt to unlock V1.6) Your X10 is running Android 2.1 - 2.3. You have a Standard NON modified Kernal on your phone (you have not flashed custom firmware to your X10) You must make sure PHONE IS NOT ROOTED BEFORE UNLOCK. You must have internet connection Trouble Shoot: Unlock Not OK or Not Detecting Phone? Possible causes: 1. On Vista or Windows 7 32/64 byte OS, client must be run as administrator (right click on shortcut, select "run as administrator") 2. Firewall or Antivirus is deleting files in the loaders folder. Uninstall software turn off antivirus and reinstall. Phone shows no service after unlock: 1. Remove Battery and wait 1 minute. Insert Battery and power on phone. Software hangs while unlocking or detecting ADB device Antivirus has deleted important files. Uninstall software.Turn off Antivirus .Download and install software again [FAQ] Q - Are the Xperia x10 mini Pro & Xperia Mini Pro the same A - No, the Xperia Mini Pro is a newer Phone, if you are unsure please check the label under the battery, the X10 mini and X10 Mini Pro are both supported (u20 & u20i) Q - Is it a permanent unlock A - Yes Q - My X10 unlock counter is blocked A - No problem, your X10 will still be unlocked. Q - If I flash the phone, the phone will get relocked ? A - No it's a permanent unlock, not a stupid "patch" unlock solution |
02-03-2013, 13:50 | #3 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,260 | For Test Point Unlocking Models: 1. Connect phone powered on to your PC 2. Install necessary drivers (drivers are located in "Program Installation Folder" folder) 3. Disconnect battery,press Unlock 4. Attach Testpoint and connect phone with Micro USB cable directly to motherboard USB port, Install drivers ( if it s installed the drivers as ZEUS FLASH DEVICE (WRONG) so to fix:
6. Follow software instructions (prompts) Trouble Shoot: Unlock Not OK or Not Detecting Phone? Possible causes: 1. On Vista or Windows 7 32/64 byte OS, client must be run as administrator (right click on shortcut, select "run as administrator") 2. Firewall or Antivirus is deleting files in the “loaders” folder. Uninstall software turn off antivirus and reinstall. Phone shows no service after unlock: 1. Remove Battery and wait 1 minute. Insert Battery and power on phone. Software hangs while unlocking or detecting ADB device Antivirus has deleted important files. Uninstall software.Turn off Antivirus .Download and install software again Last edited by Fast Unlocking; 02-28-2013 at 16:23. |
03-21-2013, 10:05 | #4 (permalink) |
No Life Poster Join Date: May 2012 Location: NCK Team
Member: 1761928 Status: Offline Sonork: 100.1626169 Thanks Meter: 804 | Huawei U8666 Ascend Y201 Pro Root + bootloader unlock + CWM Recovery [TUTORIAL] Huawei U8666 Ascend Y201 Pro Root + bootloader unlock + CWM Recovery 1. First, download zipped package. mirror link 2. Unpack files in a folder on the PC. 3. Turn on the phone when the phone is powered up, it will navigate to Settings -> Developer Tools -> USB debugging switch on. 4. connecting the phone via USB cable to PC and install the ADB drivers (if necessary) Root and bootloader unlock: Run UnlockBootLoader.exe and choose Root Your Phone (Win Vista/7 right click on exe and run as administrator). To check if the rooting worked, we look at apps that Superuser was installed. The UnlockBootLoader.exe run again and this time we choose unlock bootloader. After he made himself UnlockBootLoader, we turn off the phone. CWM recovery installing: Volume Down and press the start button simultaneously and keep pressed for about 10s-15s. The start screen should appear solid. Connect phone via USB cable to the PC. Navigate with CMD to extracted folder and type in the following. (Press on Win Vista/7 in the unzipped folder Shift + right mouse button and select Open Command Window Here) fastboot erase recovery then press Enter. fastboot flash recovery recovery.img then press Enter. (two version in the package) fastboot reboot confirm with Enter. Now you have successfully rooted your phone, unlocked bootloader and installed CWM recovery. If you need to unlock the phone, you can now simply by NCK Dongle or NCK Box. br. NCK Team Last edited by kaller1; 04-16-2013 at 09:05. |
The Following 7 Users Say Thank You to kaller1 For This Useful Post: |
05-10-2013, 14:55 | #5 (permalink) |
Member: 1761928 Status: Offline Sonork: 100.1626169 Thanks Meter: 804 | How to unlock Alcatel MTK phones if your pid's not supported? [TUTORIAL] Read codes procedure via NCK Box + NCK Box Generic MTK Flash Tool 1. Select model 2. Select com port (if phone have microUSB port, use GW300 cable) 3. Press Backup sec(alcatel) button 4. After backup done, fill IMEI window 5. Press Load backup and calculate button 6. Open backup file (NCK BOX/NCK BOX Generic MTK Flash Tool/alcapid_backup/phone model/XIB3CG22.nsb) 7. Exe read codes from backup 8. Put not accepted sim in phone and enter NCK code > unlock done br. NCK Team |
The Following 5 Users Say Thank You to kaller1 For This Useful Post: |
06-09-2013, 21:54 | #6 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,260 | NCK BOX How to use & how to install PDF Here you can find all help instructions in PDF format, and it will be updated everyday until all needed info is completed. How to Install NCK Box http://www.nckbox.com/HELP/How%20to%...0NCK%20Box.pdf How to Unlock Huawei G7010 http://www.nckbox.com/HELP/How%20to%...ei%20G7010.pdf How to unlock desire_desirehd http://www.nckbox.com/HELP/How%20to%...e_desirehd.pdf How to use Alcatel calculator http://www.nckbox.com/HELP/How%20to%...calculator.pdf How to use Blackberry Code Reader http://www.nckbox.com/HELP/How%20to%...e%20Reader.pdf How to use NCK - Xperia Test Point Unlock http://www.nckbox.com/HELP/How%20to%...t%20Unlock.pdf How to use NCK - Xperia x10 unlocking http://www.nckbox.com/HELP/How%20to%...0unlocking.pdf How to use NCK Huawei Calculator http://www.nckbox.com/HELP/How%20to%...Calculator.pdf How to use Nck Box Nokia Module http://www.nckbox.com/HELP/How%20to%...a%20Module.pdf Palm Pre & Pixi Unlock Requirements http://www.nckbox.com/HELP/Palm%20Pr...quirements.pdf BR NCK Team Last edited by Fast Unlocking; 08-26-2013 at 08:54. |
The Following 11 Users Say Thank You to Fast Unlocking For This Useful Post: |
07-10-2013, 09:20 | #7 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,260 | ★★★ Alcatel MTK Firmwares In Support Explanation ★★★ let s take OT-800 as an example: OT-800X-PMPT1 How do we name flash file: OT-803 - name of the model, in our case it's Alcatel One Touch 800 X OR A OR D etc.. - base-band settings ("A": 850/1900 band, "X": 900/1800 band & "D" Dual SIM). PMPT1 - Provider ID (firmware branding) usually it is written like this 2XPMPT1 but we take the main letters of provider id which is the last 5 letters. XR46CP1A - Secro Name: Security block version. Locked - means that after flashing phone will be locked. Unlocked - means that after flashing phone will be unlocked. Samsung OR ONYX OR any other flash chip name - is the flash IC chip inside phone so you must flash with same firmware for this flash chip. IF AFTER OT (ONE TOUCH) you see the letter V - example OT-V this mean Vodafone Phone : OT-V555 = Vodafone-555. BR NCK Team Last edited by Fast Unlocking; 07-10-2013 at 10:10. |
The Following 6 Users Say Thank You to Fast Unlocking For This Useful Post: |
08-08-2013, 20:33 | #8 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,260 | NCK Box Videos - How to use/flash/unlock/etc... Here we will upload videos related to NCK Products. How to flash BB5 Phones: NCK BOX - How to flash bb5 phone with usb cable - YouTube 4unlockers.com - NCK Dongle Nokia E52 USB-Flashing - YouTube http://www.youtube.com/watch?v=I5tcieu9VNM http://www.youtube.com/watch?v=2nr-lt5Rzos |
The Following 2 Users Say Thank You to Fast Unlocking For This Useful Post: |
08-08-2013, 20:43 | #10 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,260 | How to Unlock Nokia BB5 Phones with UFS as Interface NCK BOX - How to Unlock Nokia BB5 Phones with UFS as Interface - YouTube |
08-17-2013, 20:36 | #11 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,260 | F1310 Unlocking Video ZTE F1310, Unite F1310 - ????????????? ?? ????????? - ???????? - unlock - YouTube Enjoy with NCK Team |
09-08-2013, 18:00 | #13 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,260 | VIDEO Unlock ALCATEL OT-255a with NCK DONGLE BOX Uploaded to Support Area latest Service Manuals, more uploading will be done also. Kind Regards NCK Team |
The Following 3 Users Say Thank You to Fast Unlocking For This Useful Post: |
09-28-2013, 03:24 | #14 (permalink) |
No Life Poster Join Date: Nov 2011 Location: mexico
Member: 1681847 Status: Offline Thanks Meter: 103 | VIDEO Unlock ALCATEL OT-255a with NCK DONGLE BOX Unlock ALCATEL OT-255a with NCK DONGLE BOX |
The Following 3 Users Say Thank You to Revolution Cel For This Useful Post: |
12-28-2013, 20:17 | #15 (permalink) |
Member: 1761928 Status: Offline Sonork: 100.1626169 Thanks Meter: 804 | NCK Smart Card Driver for Win7 64 bit Many users have problems with the smart card drivers in Win7 64 bit. The problem is that the smart card driver is not installed properly, therefore removing the dongle/box after inserting again, windows tries to reinstall the driver, but fails. Here is the 100% solution and the files: 4shared link: NCK_SmartCard_Driver_Win7_64.zip mega link: NCK_SmartCard_Driver_Win7_64.zip Proper driver installing, step by step: Code: Extract the Driver Files From the Compressed Download Open Device Manager From the Control Panel in Windows 7 Locate the Hardware Device You Want to Update the Drivers For Open the Hardware Device's Properties Start the Update Driver Software Wizard Choose to Locate and Install Driver Software Manually Choose to Pick From a List of Device Drivers on Your Computer Click the Have Disk Button Click the Browse Button Navigate to the Folder with the Extracted Driver Files Choose NCK_SmartCard_Driver_Win7_64/oem18.inf File in the Folder Confirm Your Folder Choice Start the Windows 7 Driver Installation Process (click Next) Wait While Windows 7 Installs the Updated Driver Close the Update Driver Software Window Done - The windows has successfully updated your Smart Card driver NCK Team |
The Following 2 Users Say Thank You to kaller1 For This Useful Post: |
