Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 12-29-2013, 00:04   #16 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Q.-I'am have normal mtk phone and this phone not listed, how to solve?
A.-Possible your phone is supported already.
NCKBox generic mtk exe support many CPUs and phones can be supported but not listed in NCK Software
How to do:
1:- First try to see if phone can be connected by USB (easy way)
To connect by USB phone must be in boot mode.
1.2:- To connect phone by USB, phone must be off and need to press some key and insert USB cable or simple power off phone and insert USB cable.
Device manager must be opened.
First need to try with powered off phone, connect USB cable.
If all ok, lcd will remain blank and in device manager will be created new com port.
If this method not work then:
1.2.1:- Phone off and try with "MENU" button and insert USB cable
OR
Phone off & Press * Key and insert USB cable
OR
Phone off & Press # key and insert USB cable,
OR
Phone off & Press CALL button and insert USB cable, and so on(can be any key, mostly used in phones is menu, *, #, left soft key, right soft key, call button, vol-, vol+)
After each try need reinsert battery.
On success will be created new virtual com port.
Remember combination and start exe.
Select USB and press read info in service@unlock tab.
Some phones will display real code, some will display 12345678(default one) and lock status.
If READ info is OK and code is default(12345678) must be used direct unlock.
Old 12-29-2013, 00:12   #17 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Q- MTK phone stuck on boot logo, need to flash phone?
A- Usually not need to flash,many times help simple auto fat format from exe and after need to restore imei.
Q-Phone have user code enabled and exe not display user code.
A-Universal way: auto fat format from exe and after need to restore imei.
Recomened way: backup calibration, auto format fat, restore calibration.
On this opperation usually gone all user stuff, if this is important need to backup first using FILEMANAGER.
The Following User Says Thank You to orbita For This Useful Post:
Old 01-04-2014, 18:23   #18 (permalink)
Member: 1873869
Sonork: 100.1602669
Thanks Meter: 1,333
Arrow Flashing/Unlocking LG Phones with NCK Box CDMA Module
Reading Phone Info/User Lock
- Reading Phone Information and Phone Lock is very easy with NCK Box.
- Connect phone with USB Cable or RJ45 TP Cable and select proper port in CDMA Module.
- Click on Read Info. A detailed phone information will be shown.
Doing SP Unlock
- Connect Phone with USB Cable.
- Select correct Model or just click Read Info, it will automatically select correct Model.
- Click on Unlock and it will be unlocked.
Flashing Phone
- Select correct Model.
- Select Correct Flash File.
- If you are connecting phone in Emergency Mode ( 5 + PWR ) then tick Emergency Mode.
- In both Normal and Emergency Mode, software will automatically detect correct model, and will notify you if you chose wrong model.
- Click on Flash.
Repair Phones Blinking on LG Logo
- Connect Phone in Emergency Mode. ( 5 + PWR )
- You dont need to select any proper model as software will automatically detect correct model.
- Click on Blink Repair and you are done.
Writing RF/PRL/EFS Data After Flash/Blink Repair
- Connect Phone in Normal Mode.
- Select correct model, and tick RF / PRL / EFS and click on Write.
- Phone will reboot when done.
Repair/Write MEID/ESN
- Select option like ESN or MEID.
- Enter a valid ESN or MEID.
- Click on Write and you are done.
Some Advance Features available only in NCK Box CDMA Tool
- It can automatically identify if selected file is a valid Qualcomm Firmware and display file type (QSC60xx/QSC11xx).
- It will warn you if you select wrong Model and will select correct model automatically. Preventing you from killing your phone.
- If you are flashing your phone in Emergency Mode, it will read your phone model in Emergency mode and will warn you if you have selected wrong model.
- Unique EFS Writing Method lets you do it by simply clicking a button. No need to select anything. Our tool is smart enough to select things needed for your model.
Br,
NCK Team
The Following 2 Users Say Thank You to NCKCDMA For This Useful Post:
Old 01-07-2014, 02:03   #19 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Android MTK hints.
Q- My phone show invalid imei, how to solve.
A- If phone have OTP imei (alcatel as example) then simple reflash phone, imei will come.
If phone not have OTP imei then will need to repair imei.
Q- I'am maked repair imei, but after wipe phone imei reset back to default or null, how to solve?
A-In android mtk phones imei and other settings is stored in nvram partition and cached in data(userdata) partition.
When user wipe phone /data/nvram remaked from /nvram partition.
Many free tools repair imei only in /data/nvram, but in /nvram remain still empty imei and after wipe phone imei will become empty.
How to solve:Need to rebuild imei in corect way in /data/nvram and /nvram
If nvram have many damaged blocks, need to write good nvram file from other phone, same model and after make rebuild imei.
Damaged NVRAM simptoms:
Empty imei, phone not recognize sim card, network is not stable or missing, phone loop on boot logo, phone reboot in recovery after power on, wifi not work or work in strange ways.
Old 04-28-2014, 13:36   #20 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
[FAQ] My Alcatel Android phone have null IMEI. How to solve?
All Alcatel phones have IMEI in OTP area.
This mean IMEI, can't be destroyed by software.
Sometimes we have null imei.
This can happen usually in next cases:
1. Security corrupted: Full flash with format usually solve this.
2. NV area corrupted: Need to erase nv area and after perform flash with format.
3. Incompatible hardware modem with modem firmware:Need to write correct version.
4. Hardware damage, in this case need to repair phone.
How to know initial phone version if phone come already damaged:
Need to read PRO_INFO partition.
Make boot info with display partition info checked.
In long list will be line with PRO_INFO begin and end adreses.
Need to use this adreses and to read firmware using this values.
After upload in forum or use hex editor.
Version and phone name are in plain in this partition.
The Following 5 Users Say Thank You to orbita For This Useful Post:
Old 05-26-2014, 15:51   #21 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888 QQ3161545070
Thanks Meter: 97,263
How to flash Huawei Android MTK Phones
http://www.youtube.com/watch?v=LqWBavJxsbE
The Following User Says Thank You to Fast Unlocking For This Useful Post:
Old 05-26-2014, 16:03   #22 (permalink)
Member: 94675
How to change IMEI in Huawei Android Phones using NCK Dongle or Box Android MTK tool
http://www.youtube.com/watch?v=lbBCIheAx6s
The Following 2 Users Say Thank You to Fast Unlocking For This Useful Post:
Old 05-26-2014, 16:06   #23 (permalink)
Member: 94675
How to Direct Unlock Huawei Phones using NCK Dongle or Box Android MTK Tool
http://www.youtube.com/watch?v=nnI_CJWbLPE
Old 08-22-2014, 12:05   #24 (permalink)
Member: 94675
How to Change IMEI in Blackberry Qcomm Phones Using NCK Dongle & NCK Box
http://www.youtube.com/watch?v=YQdjQONsDHY
How to read Blackberry codes in supported models
http://www.youtube.com/watch?v=1HSlP9TnASY
How to Unlock 0 MEP With NCK Box or NCK Dongle
http://www.youtube.com/watch?v=-qiuP77dcNk
How to Wipe & Flash Blackberry phones with NCK Box & NCK Dongle
http://www.youtube.com/watch?v=GpXHG3I54KM
Old 06-09-2016, 01:34   #25 (permalink)
Member: 94675
New Link updated with new videos on how to use and will be updated more often
Gif Help Vidz | NCK BOX
Big Thnx to Gsm.Universal , Real Ash, and all others who contributed with this videos.
Old 11-21-2017, 11:42   #26 (permalink)
Member: 94675
NCK Dongle HELP - How to use Setups / Videos /Guides / Tutorials / Pinouts / How To?
Here is the Link all Videos Made By NCK Team to help users, more will come soon.
NCK Team - YouTube
Latest Video:
ZTE V768 Unlocking By NCK Team
ZTE V768 Unlocking By NCK Team - YouTube
1st You must Download support access exe, then extract from zip file.
Support Access Download link:
Download Area
http://www.youtube.com/watch?v=sGCD5RlAazg
How to Install main module?
Note: this card is already activated, so software will start normally to know how to update for fist time use, check the post number 3.
http://www.youtube.com/watch?v=SRzdyu7N8Vs
How to update NCK Dongle in order to start using it?
http://www.youtube.com/watch?v=fBFh_XBe7VM
How to install NCK Dongle Samsung module?
http://www.youtube.com/watch?v=lBrdQx_40_o
How to install NCK Dongle MTK Flasher module?
http://www.youtube.com/watch?v=TvSLKbxiu4g
The Following 3 Users Say Thank You to Fast Unlocking For This Useful Post:
Old 11-21-2017, 11:43   #27 (permalink)
Member: 94675
Many users have problems with the smart card drivers in Win7 64 bit. The problem is that the smart card driver is not installed properly, therefore removing the dongle/box after inserting again, windows tries to reinstall the driver, but fails.
Here is the 100% solution and the files:
4shared link: NCK_SmartCard_Driver_Win7_64.zip
mega link: NCK_SmartCard_Driver_Win7_64.zip
Proper driver installing, step by step:
Extract the Driver Files From the Compressed Download
Open Device Manager From the Control Panel in Windows 7
Locate the Hardware Device You Want to Update the Drivers For
Open the Hardware Device's Properties
Start the Update Driver Software Wizard
Choose to Locate and Install Driver Software Manually
Choose to Pick From a List of Device Drivers on Your Computer
Click the Have Disk Button
Click the Browse Button
Navigate to the Folder with the Extracted Driver Files
Choose NCK_SmartCard_Driver_Win7_64/oem18.inf File in the Folder
Confirm Your Folder Choice
Start the Windows 7 Driver Installation Process (click Next)
Wait While Windows 7 Installs the Updated Driver
Close the Update Driver Software Window
Done - The windows has successfully updated your Smart Card driver
Old 11-21-2017, 11:43   #28 (permalink)
Member: 94675
How to start using NCK Dongle read below:
1. Download setups software
Support software
2. Download drivers for your card reader, exits 3 card readers type for nckdongle.
Standard PCSC driver(pkey like)
Rockey200 drivers
SCR3310 v2.0 USB SC Reader
3. Insert dongle in usb port and install needed driver.
4. Start Support access software.
If all ok you can see your serial number and can access support.
If exe not show serial number and acces directly nckdongle.com page this meen problem with drivers or with dongle(card reader).
Please note: some antivirus programs may give a warning, ignore it, there is no virus, its smartcard protection.
After downloading NCK Dongle main installer.
For New users also need to follow the above steps then carry on with the steps below:
Start NCK Dongle Main Module, Press Update card, after updating you must close software and start it again.
That's all and you are ready use NCK Dongle & Make some money
If you see an error like below when trying to update card:
CardID_to calculate: 000000x
CardID:00000x
Response:2
Card not registered in server
then send "orbita" or "Fast Unlocking" a PM with card serial and the reseller name and your date of purchase.
We will then add your card into server database.
PLEASE NOTE: If after the card update, application still says update the card counter then please check the clock/time of your computer as the card counter update is based on computer local time and server time (also make sure your date and time is correct).
Old 11-21-2017, 11:44   #29 (permalink)
Member: 94675
How to Access NCK Dongle Support Area From Main NCK Dongle Module to Download & update new version update or firmwares or drivers for current NCK Dongle users.
http://www.youtube.com/watch?v=JB76MBqOliM
Old 11-21-2017, 11:46   #30 (permalink)
Member: 94675
MSVCR100.DLL is C Runtime Library used by many applications.
There are very little chances that this file does not exist on your system.
In such case, running NCK Box will show you error saying:
"The Program can't start because MSVCR100.DLL is missing from your computer."
Solution is easy, just download attached archive and extract it.
You will have MSVCR100.DLL. Place it either in C:\NCKBOX folder or copy it to your System folder (ie. C:\Windows\System32).
Page generated in 0.29142 seconds with 8 queries
