08-12-2021, 15:39 | #1 (permalink) |
Junior Member Join Date: Jun 2021 Location: Botswana Age: 33
Member: 2990988 Status: Offline Sonork: NULL Thanks Meter: 0 | How to remove frp in alcatel 1t7 tablet Which step I may not be following? |
02-18-2022, 08:37 | #3 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Hungary Age: 40
Member: 22869 Status: Offline Thanks Meter: 132 | same problem, heres the log (Alcatel 1T7 also known as TCL 9309X, with android go) Code: Exe version: NCKDongle AndroidMTK 2.7.7 Selected phone: ELBRUS Action: Backup security items Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(50) : MediaTek PreLoader USB VCOM_V1632 (Android) (COM50) [50] \\?\usb#vid_0e8d&pid_2000#5&2108ad5d&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Preloader Phone detected...Please wait BBCHIP: 8167 1 cb00 Using Algo 1. Helio MT8167 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... Helio connect da error, aborting. [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware BBCHIP MT8167 Boot Fail.!!!. [helio]Wait untill phone will start charging. [0]All done. |
02-18-2022, 09:18 | #4 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Code: [SECURE BOOT]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model If model is not listed, use custom DA from phone firmware You have 2 posible variants. 1.If phone is listed in exe, folow exe hint. 2.If phone is not listed in exe try "bypass security" function. Last edited by orbita; 02-18-2022 at 19:41. |
The Following User Says Thank You to orbita For This Useful Post: |
02-18-2022, 09:35 | #5 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | In all exes, no matter compiler used, or who compiled exe, combobox work in same way. Need to scroll items and select needed item. You really not know how to use comboboxes in exe ? If you really want to select cpu, and not know how to do this, check in atached screenshot. Last edited by orbita; 02-18-2022 at 19:41. |
02-23-2022, 07:39 | #6 (permalink) |
Member: 22869 Status: Offline Thanks Meter: 132 | I really like your enthusiasm and your product but who told you im blind to read? This cheap tablet is not in the list, I was unable to find firmware so gave back to customer. Your help always welcome |
02-23-2022, 12:57 | #7 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
We really can't guess your problem without aditional info about problem. Posting just to post, will not keep forum clean. | |
