Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 11-24-2021, 23:32   #1 (permalink)
Punto-Móvil's Avatar
Member: 1147852
Thanks Meter: 587
huawei g7 l01 stuck on qualcomm hs port
Hi there nck team,
this is the second huawei device after flash with qualcomm module hangs on Qualcomm HS-USB QDLoader 9008.
any suggestion to solve this issue ?
Punto-Móvil
Exe Version: NckDongle Qualcomm Module 0.12.8
Operation: Upgrade
Searching for phone.....
Qualcomm HS-USB QDLoader 9008 (COM22) detected.
Hello received.
HW ID: 00000000E1507000 MSM8916
PK HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F
Checking database for suitable loader.....
Arhitecture:32 bits
[32]Sending loader, please wait..
Waiting for loader to start...
[1] Send NOP ok, loader start.
CPU: MSM8916
MaxPayloadSizeFromTargetInBytes: 4096
MaxPayloadSizeToTargetInBytes: 8192
Reading partition info, wait.
Volume[0] Size: 14.68 GB Partitions count: 24
[01733FDF]Userdata Size: 11.6 GB
[0]Writing: sbl1 Start: 34 length: 561
[0]Writing: hyp Start: 1058 length: 40
[0]Writing: rpm Start: 16384 length: 284
[0]Writing: tz Start: 17408 length: 793
[0]Writing: aboot Start: 18432 length: 2666
[FLASH][SKIP] name: modemst1
[FLASH][SKIP] name: modemst2
[0]Writing: fsg Start: 376832 length: 115
[0]Sparse writing: persist Total chunks: 10 BlockSize: 4096 Sector Size: 512
[0]Writing: boot Start: 589824 length: 34920
[0]Writing: recovery Start: 630784 length: 36828
[0]Sparse writing: cust Total chunks: 117 BlockSize: 4096 Sector Size: 512
[0]Sparse writing: cache Total chunks: 15 BlockSize: 4096 Sector Size: 512
[0]Sparse writing: system Total chunks: 2893 BlockSize: 4096 Sector Size: 512
[0]Sparse writing: userdata Total chunks: 70 BlockSize: 4096 Sector Size: 512
[FLASH][SKIP] name: PrimaryGPT
Applying patch, wait...
Error write frame, aborting.
Restarting phone.....
Log saved: C:\Users\The-Master\Documents\NckDongle\qualcomm_module\qc_modu le_Logs\flash_phone_MSM8916_00000000E1507000_CC315 3A80293939B90D02D3BF8B23E0292E452FEF662C74998421AD AD42A380F1.txt
Total Time: 00:24:22
Done.
Old 11-25-2021, 08:35   #2 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Not sure what to say, but based on log, you only updated firmware, and skipped gpt.
And after exe gived this error
Update firmware is recomended only on working phone when you update android version with same firmware version or write only some partitions with same size in phone.
But if you write other firmware with different size and will skip gpt, will be problem.
If battery will be discharged, can be also problem.
Also if emmc have bad sectors or problems also will be problem.
This last command what give error, in fact apply firmware in phone from phone memory.
If you sure about firmware, will recomend you to check battery first, and after write full firmware, and see what happen.
This metod what you used, is like safe flash in android mtk, will preserve some data in phone, on writing, but you must be sure when and why you use this metod, if you not sure, need to perform full flashing.
The Following 2 Users Say Thank You to orbita For This Useful Post:
Page generated in 0.11888 seconds with 8 queries
