02-01-2023, 19:13 | #4 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Unknown baseband repair without user intervention is not posible. This issue can be caused: 1.Damaged or erased phone static nvram partition. Need to delete nvram and nvdata partition, power on phone and after power off. After need to perform backup/restore nvram in spmeta mode or repair imei in spmeta mode. In this case will be rebuilded buth dinamic(nvdata) and static(nvram) partitions. 2.Damaged, corupted, or not fully compatible firmware. In this case need to flash compatible firmware Some phones not allow downgrade and can cause this problem by downgrading firmware. 3.Damaged or corupted security, in modern phones this can be solved formating protect1 and protect2 partitions. 4.Hardware problems. In this case need to perform hardware repair. Exe allow you to solve all software problems what cause unknown baseband. Unfortunately exe can't solve hardware problems what can cause unknown baseband. Because of multiple problems what can cause this issue is not posible to have one big button called repair baseband. To solve problem corectly need skilled technician who know what he do. Using our exe, sure. |
