07-10-2021, 16:36 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,241 | Nck Box / Pro Android MTK Module v2.7.6 Update Released - [10/07/2021] - Changed Bypass security function. -- Now it become more fast, and take 2..3 sec in new exe version to bypass security. - Enabled dump Preloader and EMMI initialization for not secure phones booted in Brom mode. -- This feature allow to not use Preloader and scatter to boot such phones. - Added direct EMMI initialization for not Helio cpu, this will allow to handle directly phones with MT6535, MT6737, MT6580 cpu etc... -- This must solve problem with unknown or not added in database flash ic id, exe will dump it directly from phone. - Added checking for brom and preloader mode, using "bypass security" function. -- It will not allow booting in wrong mode. - Changed security Bypass payload's, will allow to dump more accurate preloader from phone. Supported cpu for bypass security with auto detection:
- Improved speed and stability for software testpoint function -- This function is important if need to use other tools like SP Flash tool and need to bypass phone security. Official Website: NCK Box Download From Support Area Or Google Drive https://drive.google.com/file/d/15Fb...ew?usp=sharing Or MediaFire ****************************/file/gqupr...2_9_6.rar/file |
The Following 13 Users Say Thank You to Fast Unlocking For This Useful Post: |
07-10-2021, 16:37 | #2 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,241 | Code: Redmi 9 using "bypass security Flash files count is :25 Action : Firmware update. Selected Model: 0-By CPU: ELBRUS Exe version: NCKDongle AndroidMTK 2.7.5 Scenario: [0]Safe Flash Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button until inserting USB cable. For some phones need to keep "VOL+ and VOL-" button until inserting USB cable. For some phones need to keep "VOL+" button until inserting USB cable. Detected(21) : MediaTek USB Port (COM21) [21] \\?\usb#vid_0e8d&pid_0003#6&3b2f04e1&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6768 CPU code: 707 Target config: e7 Secure boot enabled: true Need serial link authorization: true Need download agent authorization true Executing exploit, do not disconnect phone Exploit has been executed successfully. Dumping phone preloader. Waiting for handle to become active...... Received active handle reply from phone...... Booting phone Detected(21) : MediaTek USB Port (COM21) [21] \\?\usb#vid_0e8d&pid_0003#6&3b2f04e1&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6768 0 ca00 Using Algo 1. Helio MT6768 phone detected, swithing to helio api Loading emmi from download Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6768 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010044503644 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe91000000 [58.266 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat operation. Detected(20) : MediaTek DA USB VCOM (Android) (COM20) [20] \\?\usb#vid_0e8d&pid_2001#6&3b2f04e1&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting flash Helio. [2] WRITE TO PARTITION [ recovery ] [7] WRITE TO PARTITION [ vbmeta ] [8] WRITE TO PARTITION [ vbmeta_system ] [9] WRITE TO PARTITION [ vbmeta_vendor ] [21] WRITE TO PARTITION [ efuse ] [24] WRITE TO PARTITION [ logo ] [25] WRITE TO PARTITION [ md1img ] [26] WRITE TO PARTITION [ spmfw ] [27] WRITE TO PARTITION [ scp1 ] [28] WRITE TO PARTITION [ scp2 ] [29] WRITE TO PARTITION [ sspm_1 ] [30] WRITE TO PARTITION [ sspm_2 ] [33] WRITE TO PARTITION [ lk ] [34] WRITE TO PARTITION [ lk2 ] [35] WRITE TO PARTITION [ boot ] [36] WRITE TO PARTITION [ dtbo ] [37] WRITE TO PARTITION [ tee1 ] [38] WRITE TO PARTITION [ tee2 ] [45] WRITE TO PARTITION [ super ] [46] WRITE TO PARTITION [ cache ] [47] WRITE TO PARTITION [ userdata ] HINT: If phone stuck on logo, for some phones help factory reset. Select factory reset tab/reset to factory default. [Helio]Wait until phone will start charging. [0]All done. |
The Following 8 Users Say Thank You to Fast Unlocking For This Useful Post: |
07-10-2021, 19:13 | #3 (permalink) | |
Product Supporter Join Date: Apr 2016 Location: India
Member: 2562751 Status: Offline Thanks Meter: 60 | Quote:
Sent from my Mi 9T using Tapatalk | |
The Following User Says Thank You to Sourovgsm For This Useful Post: |
07-11-2021, 05:26 | #5 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Kampala,Uganda
Member: 2294589 Status: Offline Thanks Meter: 116 | Hello sir does this update support imei repair on nokia 2.4 (1270,1206) and many others because after flashing these phones imei get lost otherwise thanks for the update |
07-11-2021, 06:43 | #6 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | super speed read info cph2179 .. thanks Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 2.9.6 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(12) : MediaTek USB Port_V1632 (COM12) [12] \\?\usb#vid_0e8d&pid_0003#5&147efee4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6765 CPU code: 766 Target config: e5 Secure boot enabled: true Need serial link authorization: false Need download agent authorization true Executing exploit, do not disconnect phone Exploit has been executed successfully. Dumping phone preloader. Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(12) : MediaTek USB Port_V1632 (COM12) [12] \\?\usb#vid_0e8d&pid_0003#5&147efee4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6765 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010044483644 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe91000000 [58.266 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(14) : MediaTek DA USB VCOM (Android) (COM14) [14] \\?\usb#vid_0e8d&pid_2001#5&147efee4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Build ID: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys Version: 10 Build Date: Mon Dec 28 21:16:32 CST 2020 This phone have FRP partition. Phone have OTP partition. Modem version: MOLY.LR12A.R2.TC16.Q.G35.PR1.SP.V2.P133 [helio]Wait untill phone will start charging. [0]All done. Exe version: NCKBox AndroidMTK 2.9.6 Selected model: 0-By CPU ELBRUS [auto]Action: Reset FRP Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(12) : MediaTek USB Port_V1632 (COM12) [12] \\?\usb#vid_0e8d&pid_0003#5&147efee4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6765 CPU code: 766 Target config: e5 Secure boot enabled: true Need serial link authorization: false Need download agent authorization true Executing exploit, do not disconnect phone Exploit has been executed successfully. Dumping phone preloader. Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(12) : MediaTek USB Port_V1632 (COM12) [12] \\?\usb#vid_0e8d&pid_0003#5&147efee4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6765 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010044483644 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe91000000 [58.266 GB] Resetting userdata. [--0] writing to cache Phone have OTP partition. Modem version: MOLY.LR12A.R2.TC16.Q.G35.PR1.SP.V2.P133 Starting helio frp, not disconnect phone untill done [HELIO][frp]Format partition, please wait... [0]FRP Reset Done. [helio]Please power phone in recovery mode(VOL +) to complete action. [0]All done. |
The Following User Says Thank You to malka4u For This Useful Post: |
07-20-2021, 01:36 | #10 (permalink) |
Freak Poster Join Date: Dec 2017 Location: philippines
Member: 2785467 Status: Offline Sonork: 100.1679506 Thanks Meter: 28 | update good great update sir. please add xiaomi/redmi . just suggestion |
The Following User Says Thank You to azofs For This Useful Post: |
08-05-2021, 07:43 | #11 (permalink) | |
Insane Poster Join Date: Oct 2017
Member: 2770819 Status: Offline Thanks Meter: 3 | Quote:
how to set in brom mode? | |
