06-15-2021, 11:11 | #16 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | is mtk all in one loader from SP_Flash_Tool_v5.1924_Win working for me |
06-15-2021, 11:17 | #17 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
before was v5.1820 version, not exe use v5.2033 version. Can you download again installer, install it and test with your phone. | |
The Following User Says Thank You to orbita For This Useful Post: |
06-15-2021, 12:47 | #18 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | thank you very much every thing working fine now with fix version Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 2.9.5 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(12) : MediaTek USB Port_V1632 (COM12) [12] \\?\usb#vid_0e8d&pid_0003#5&147efee4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6765 CPU code: 766 Target config: e7 Secure boot enabled: true Need serial link authorization: true Need download agent authorization true Executing exploit, do not disconnect phone Exploit has been executed successfully. Dumping phone preloader. Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(12) : MediaTek USB Port_V1632 (COM12) [12] \\?\usb#vid_0e8d&pid_0003#5&147efee4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6765 0 ca00 Using Algo 1. Helio MT6765 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6765 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 880103534C4433 : 000000000000000000 EMMC UA SIZE: 0x73a000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x73ac00000 [28.918 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(14) : MediaTek DA USB VCOM (Android) (COM14) [14] \\?\usb#vid_0e8d&pid_2001#5&147efee4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} This phone have FRP partition. Phone have OTP partition. Modem version: MOLY.LR12A.R3.MP.V118.11.P7 [helio]Wait untill phone will start charging. [0]All done. |
The Following 2 Users Say Thank You to malka4u For This Useful Post: |
06-16-2021, 15:02 | #19 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Offline Thanks Meter: 933 | infinix smart 4 boot authorization bypass works perfect infinix smart 4 boot authorization bypass works perfect Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 2.9.5 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(10) : MediaTek USB Port_V1632 (COM10) [10] \\?\usb#vid_0e8d&pid_0003#5&f86e282&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6761 CPU code: 717 Target config: e5 Secure boot enabled: true Need serial link authorization: false Need download agent authorization true Executing exploit, do not disconnect phone Exploit has been executed successfully. Dumping phone preloader. Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(10) : MediaTek USB Port_V1632 (COM10) [10] \\?\usb#vid_0e8d&pid_0003#5&f86e282&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6761 200 ca01 Using Algo 1. Helio MT6761 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6761 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010051443633 : 000000000000000000 EMMC UA SIZE: 0x747c00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x749400000 [29.145 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(12) : MediaTek DA USB VCOM (Android) (COM12) [12] \\?\usb#vid_0e8d&pid_2001#5&f86e282&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Build ID: PPR1.180610.011 Display ID: X653C-H6114GH-PGo-200328V225 Version: 9 Build Date: Sat Mar 28 03:33:56 CST 2020 Model: Infinix X653C Brand: Infinix Device: Infinix-X653C Manufacturer: INFINIX MOBILITY LIMITED Mediatek Version Release: X653C-H6114GH-PGo-200328V225 This phone have FRP partition. Phone have OTP partition. Modem version: MOLY.LR12A.R3.MP.V71.11.P21 [helio]Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to dereje For This Useful Post: |
07-02-2021, 07:14 | #22 (permalink) |
Freak Poster Join Date: Sep 2018 Location: korea
Member: 2863121 Status: Offline Thanks Meter: 8 | nck android mtk v2.9.5 download problem hello sir when i want to download nck andrroid mtk through nck main module support area this version of android mtk tool doesn't exist just there is old versions in the list and when i download it from the link which you shared in this post and after instaling it when i want to run it i will get nck box card not found please help me to solve this problem thank you |
07-02-2021, 07:44 | #23 (permalink) | |
Also i'am checked buth links from first post, and buth work. Not understand really your complain Last edited by orbita; 07-02-2021 at 08:02. | |
09-30-2021, 14:04 | #27 (permalink) |
Junior Member Join Date: Apr 2019 Location: mozambique tete
Member: 2903755 Status: Offline Thanks Meter: 1 | Exe version: NCKBox AndroidMTK 2.9.5 Selected model: Alcatel OT-5033G Action: Unlock Phone must be off with battery inside. Battery must be charged Please insert USB cable now... For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(177) : MediaTek USB Port (COM177) [177] \\?\usb#vid_0e8d&pid_0003#6&1778337&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [260]META Port Detected: MediaTek USB VCOM (Android) (COM260) USB\VID_0E8D&PID_200E&MI_01\7&701CDD8&0&0001 Start sync target, waiting responce..... ChipID: MT6739,S01 [MT6739,S01]Using Algo 5 Start sync target, waiting responce..... [META]BaseBand CPU : MT6739 [META]SW_VER : MOLY.LR12A.R2.MP.V18.P160 [META]HW_VER : TK_MD_L4_HW [helio]Read simlock info. IMEI Location: OTP Phone imei[1] : 358710104313236 Start direct unlock[SIM1] Simlock checksum is ok. Direct unlock not done [0]All done. need help on this |
09-30-2021, 14:17 | #28 (permalink) | |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Quote:
TRY IN FLASH MODE ONE MORE TIME | |
The Following User Says Thank You to malka4u For This Useful Post: |
10-13-2021, 14:31 | #29 (permalink) |
Junior Member Join Date: Jun 2017
Member: 2729868 Status: Offline Thanks Meter: 7 | Where should i download nck box setups please? where should i download nck box setups? i have google drive but not working,mediafire not working and support access giving errors. |
10-13-2021, 19:58 | #30 (permalink) | |
You can use main module to acess support and download installers. google drive and mediafire we use as aditional links for fast download, and have limited time, indeed. You can download main module from oficial site, or from sticky post named Direct link for support acess software and installers Last edited by orbita; 10-13-2021 at 20:16. | |
