02-04-2020, 21:04 | #1 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1632189 Status: Offline Thanks Meter: 2 | Please NCK team help |
02-04-2020, 21:49 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | You can read database directly from phone. But on new security need to perform direct unlock by flash mode, meta mode is closed in this firmwares. |
02-05-2020, 11:01 | #3 (permalink) | |
Member: 1632189 Status: Offline Thanks Meter: 2 | no work team Quote:
in the software this flash method does not come out only the meta mode and you need it for the release to be effective on 5059_database plase post the 5059_database_zip I need to release this cell urgently of suport support don't download me tell me this Invalid link provided, please login from exe. | |
02-05-2020, 11:15 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Will keep my answer, what exactly stop you to backup database from phone? Check screenshot. And yes, old support acess not work, this was reason for today update. If you will update main module, support acess will work. Use this version of exe to perform unlock in flash mode. Uninstall old version first. https://publicfolder.s3.eu-central-1...dMTK_Setup.rar Last edited by orbita; 02-05-2020 at 11:25. |
02-05-2020, 18:10 | #5 (permalink) | |
Member: 1632189 Status: Offline Thanks Meter: 2 | thanks Quote:
thanks sp much problem is solvet | |
02-05-2020, 23:43 | #7 (permalink) |
Member: 1632189 Status: Offline Thanks Meter: 2 | Done Exe version: NCKBox AndroidMTK 2.4 Selected model: Alcatel OT-5059A Action: Unlock Will be used database connection. Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [45]Detected: MTK USB Port (COM45) \\?\usb#vid_0e8d&pid_0003#5&161222a6&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [44]META Port Detected: Gadget CDC VCOM Driver (COM44) USB\VID_0E8D&PID_2007\5&161222A6&0&2 ChipID: MT6739,S01 [MT6739,S01]Using Algo 5 Starting META using port[COM44], wait... BaseBand CPU : MT6739 MODEM SW Version : MOLY.LR12A.R2.MP.V18.P121 MODEM HW Version : TK_MD_L4_HW IMEI location: OTP IMEI[1] : 354454095066586 IMEI[2] : 000000000000000 [1]Reading simlock info: Block1(N): Unlocked Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked [1]Unlocking target, wait Direct Unlock Done. [2]Reading simlock info: Block1(N): Unlocked Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked [2]Unlocking target, wait Direct Unlock Done. [0]All done. |
The Following User Says Thank You to patonsystems For This Useful Post: |
