03-08-2020, 11:33 | #1 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2669864 Status: Offline Sonork: [email protected] Thanks Meter: 42 | It is possible to repair Xiaomi note 8 Pro IMEI with nck box |
03-08-2020, 12:33 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Meta mode, is not model dependent. Without connecting phone is very hard to say if it will work for you or not. You can send me phone, i'am will connect it to exe and will say you if it work or not. |
03-08-2020, 16:02 | #3 (permalink) |
Member: 2669864 Status: Offline Sonork: [email protected] Thanks Meter: 42 | here bis the error i got from meta mode xe version: NCKBox AndroidMTK 2.6 Selected phone: ELBRUS Action : IMEI REPAIR. IMEI[2] for write : 358265090676563 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [19]Detected: MediaTek USB Port (COM19) \\?\usb#vid_0e8d&pid_0003#6&2e98c2b&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... [7d5]Error: S_BROM_CMD_STARTCMD_FAIL Error open meta port[COM0]. [0]All done. |
03-08-2020, 16:04 | #4 (permalink) |
Member: 2669864 Status: Offline Sonork: [email protected] Thanks Meter: 42 | In flash mode here is th error Action : IMEI REPAIR. IMEI[2] for write : 358265090676563 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM19) Boot mode: Brom Brom stage DA fail, aborting [STATUS_SEC_AUTH_FILE_NEEDED][AUTH]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model Or load auth file manually in exe Boot Fail.!!!. [0]All done |
