12-02-2014, 15:30 | #2611 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | Brand: Alcatel android Model: OT-6037Y IMEI :864694020344490 Connecting to server please wait... PID: VNRS1 SECRO: x3e0ee01ar10 NCK: 3930532230 NSCK: 1956542222 SPCK: 2966126990 CPCK: 1819575231 CCK: 3173994802 Calculated by NCKServer. With non accepted simcard , insert code Alternative metod: Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK If code wrong, please dump SECRO with "ANDROID MTK" exe and report in forum. New firmware version can generate wrong code, use cable unlock!!!! -------------------------- Log saved to: logs\AlcatelAndroid_OT-6037Y_864694020344490_codecalculate_1.txt All done |
12-03-2014, 08:52 | #2613 (permalink) |
Registered User Join Date: Mar 2010
Member: 1260168 Status: Offline Thanks Meter: 62 | OLIVE V C2330 16mb blinking repaired successfully here is lo Module Ver. : 2.1 Com Port : COM2 : Olive CDMA Device HS-USB Diagnostics (COM2) Baud Rate : 115200 Device : Haier OL2330 Operation : Flash (Emergency) Port opened. Preparing Phone.. Sending bootloader... Executing Bootloader... Initializing Flash Chip... Flash Chip : SPANSION S71VS128RB0d Chip Size : 16 MB Flash File : V-C2330_MT05_16MB.BIN File Size : 16 MB Writing Firmware, Please Wait... Resetting Phone... Operation finished. Port closed. Elapsed Time: 07:19 |
12-03-2014, 09:41 | #2614 (permalink) |
Freak Poster Join Date: Apr 2011
Member: 1559546 Status: Offline Thanks Meter: 10 | SELECTED : OT-2040G Start Detect phone. Remove the battery and connect handset to PC via USB cable. After long press MENU while inserting the battery. Detected: SCI USB2Serial (COM35) Download mode ok. BOOT: SPRD3 Sending loader, wait. BOOT OK: Spreadtrum Boot Block version 1.2 CPU: 6531 Changing Baud. Reading Flash Info, wait... Flash Size: $400000 Fixed NVRAM adress: $3A8000 EFS start adress: $3B0000 PROD_INFO: $3AEC00 SIMK: $3A0000 Start UNLOCK, wait. Pathing simlock area, wait. Write File Done. Job done. |
The Following User Says Thank You to gsmslution For This Useful Post: |
12-03-2014, 10:37 | #2615 (permalink) |
Freak Poster Join Date: Sep 2014 Location: philippines
Member: 2256970 Status: Offline Thanks Meter: 67 | excited 503d unlock done Scanning for presents meta ports... Meta ports not detected, starting brom stage. Phone must be off with battery inside. Please insert USB cable now... Detected(0) : MediaTek PreLoader USB VCOM Port (COM162) Starting META mode, wait... If drivers missing, please install CDC drivers. META ok, waiting for meta port.... META Port Detected[13] Android Gadget VCOM Driver (COM13) Start sync target, waiting responce..... BaseBand CPU : MT6572, E01 SW_VER : MOLY.WR8.W1315.MD.WG.MP.V4.P2 HW_VER : HEXING72_WET_JB3_HSPA_HW Phone imei[1] : 35783405123908 Phone imei[2] : 35783405123909 Start direct unlock[SIM1] Direct unlock done Start direct unlock[SIM2] Direct unlock done Direct unlock done Direct unlock done |
The Following User Says Thank You to Naps For This Useful Post: |
12-03-2014, 11:57 | #2616 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Hell
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | zte v795 unlock THX ORBITA, Scanning for presents meta ports... Meta ports not detected, starting brom stage. Phone must be off with battery inside. Please insert USB cable now... Detected(0) : PreLoader USB VCOM (Android) (COM34) Starting META mode, wait... If drivers missing, please install CDC drivers. META ok, waiting for meta port.... META Port Detected[117] Tinno S9091 USB VCOM (Android) (COM117) Start sync target, waiting responce..... BaseBand CPU : MT6572, E01 SW_VER : MOLY.WR8.W1315.MD.WG.MP.V1.P11 HW_VER : ZZTENJ72_WE_JB3_HSPA_HW Phone imei[1] : 86337202193184 Phone imei[2] : FFFFFFFFFFFFFF Start direct unlock[SIM1] Direct unlock done Start direct unlock[SIM2] Direct unlock done Direct unlock done Direct unlock done All done. |
The Following 2 Users Say Thank You to bighiner For This Useful Post: |
12-03-2014, 14:03 | #2617 (permalink) |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | HTC desire C unlock done by nck dongle. here is log ------------- MODEL 1: Desire C MODEL 2: HTC Desire C / golfu OS VERSION: ANDROID 4.0.3 IML74K FIRMWARE: 2.00.771.2 / 10.11.98.09H_1.06.98.13M2 IMEI: 35227************BOOTLOADER: 1.28.0000 HTC HWID: golfu-1 KERNEL VERSION: 3.0.16-g0be4e84 HTC CID: H3G__001 HTC MID: PL0111000 CpuInfo: ARMv7 Verifying root Root ok Unlocking Plz wait... calculating codes plz wait... Simlock Status : Locked. Network Code : 02289456 Unlock Done. Log saved to : C:\NCK Dongle\NCK Dongle HTC Module\logs\HTC_DESIRE_C_log5.txt ------------------------------ how to copy text from cmd ----------------- Right-click the title bar of the command prompt window, point to Edit, and then click Mark. Click the beginning of the text you want to copy. Press and hold down the SHIFT key, and then click the end of the text you want to copy (or you can click and drag the cursor to select the text). |
The Following User Says Thank You to quasim0438 For This Useful Post: |
12-03-2014, 15:05 | #2618 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | ARTEL H35 reset user code done by nck dongle ARTEL H35 reset user code done by nck dongle Code: Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM6 Phone detected...Please wait Conected ok with target ... Reopen comport(COM6) BaseBand CPU : MT6250 SW_VER : H20__UZBEKISTAN__H0011 HW_VER : AHONG50_12864_11B_HW Meta mode conected ok, start reading phone.... User code(Active) : 5858 User code reset :OK META END OK. |
The Following User Says Thank You to UzUnlocker For This Useful Post: |
12-03-2014, 15:51 | #2619 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | Serial :XXXxxxxXX Active credits: 5.7 Your IP :XXX.xxx.XX.xxx SERVER RETURN: IMEI: 8657050242XXXXX Unlock Codes: 1972151631032142 1611469108171202 1811652088537741 9995616115120610 -------------------------- Log saved to: logs\HUAWEI_AllLevels+ResetKey_8657050242XXXXX_log 2.txt |
The Following User Says Thank You to zvrrr For This Useful Post: |
12-03-2014, 16:15 | #2620 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | Lg e440 Serial :XXXXXXXXX Active credits: 5.3 Your IP :xxx.XXX.xx.XXX SERVER RETURN: IMEI: 3526360624XXXXX Unlock Codes: SIM_UNLOCK=5630935127530316 NSLCKUNLOCK=5460913216565281 CLCKUNLOCK=4336535659220972 PCKUNLOCK=6242024096317235 SP_LOCK=9756760262725208 -------------------------- Log saved to: logs\LG_WorldwideAllLevels_3526360624XXXXX_log2.tx t Last edited by zvrrr; 12-03-2014 at 16:24. |
12-03-2014, 22:26 | #2622 (permalink) |
Major Poster Join Date: Aug 2006 Location: nvo.laredo,mex
Member: 333298 Status: Offline Thanks Meter: 24 | Huawei U5200 nextel mx Serial :10x00xxx0 Active credits: 22.5 Your IP :xxx.235.212.xx SERVER RETURN: IMEI: 35750104XXXXXX2 Unlock Codes: 972272396315xxxx 941591485972xxxx 151157216203xxxx 292511319823xxxx Last edited by Fast Unlocking; 12-03-2014 at 22:54. |
12-03-2014, 22:35 | #2624 (permalink) |
Member: 333298 Status: Offline Thanks Meter: 24 | Zte z992 Serial :10X00XXX0 Active credits: 22.5 Your IP :XXX.235.212.XX SERVER RETURN: IMEI: 86481801XXXXXX9 Unlock Codes: 8107980237480389 |
The Following User Says Thank You to yago98 For This Useful Post: |
12-04-2014, 01:11 | #2625 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Serbia
Member: 55980 Status: Offline Thanks Meter: 78 | Unlock Huawei U8687 How U8686 Killing adb server OK Found Device:00664B05F9EF Brand : Huawei Model : Huawei-U8687 Build ID : HuaweiU8687 Device Rooted. Reading data wait... Version : 4.0.4 Product Name : U8687 Manufacturer : HUAWEI Build ID : HuaweiU8687 Phone Unlocked All done |
The Following User Says Thank You to YuMERA For This Useful Post: |
