12-04-2014, 08:26 | #2626 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | iPhone Full GSX Info Active credits: 4.5 Your IP :XX.xx.XXX.xx SERVER RETURN: IMEI: 0132750096xxxx Unlock Codes: Serial Number: DX6JP7BJxxx Initial Activation Policy ID: 2xx MEID: Activation Policy Description: Telia SE Country Purchased: Sweden Policy IMEI: 013275009xxxxxxx Applied Activation Policy ID: 2xx Part Description: IPHONE 4G 8GB Black Applied Activation Policy Description: Telia SE. Product Version: xxxx Next Tether Policy ID: 2xxx Last Restore Date: Next Tether Activation Policy Description: Telia SE Locked Policy First Unbrick Date: 01/01/13 Last Unbrick Date: 01/01/13 Unbricked: true Find My iPhone: Off Unlocked: Flase -------------------------- Log saved to: logs\IPHONE_iPhoneFullGSXInfo_01327500966xxxx_log2 .txt Last edited by Fast Unlocking; 12-04-2014 at 09:16. |
The Following User Says Thank You to zvrrr For This Useful Post: |
12-04-2014, 12:00 | #2628 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | S5360 unlock done Model Selected : GT-S5360 If Phone ask sor SU acces, Allow it. LCD must be ON and unlocked. Found Device : 0123456789ABCDEF MODEL : GT-S5360 BOARD ID : totoro PLATFORM ID : bcm21553 OS VERSION : 2.3.6 BUILD ID : GINGERBREAD BUILD DATE : Wed Mar 27 13:10:50 KST 2013 BUILD VERSION : GINGERBREAD.XXMC2 SOFTWARE VERSION : S5360XXMC2 IMEI : 3546610557XXXXX (GSM)RIL VERSION : BRCM android bcm-ril-090728 (GSM)BASEBAND : S5360XXMC2 (RIL)SW VERSION : S5360XXMC2 (RIL)(RIL)HW VERSION : MP 0.701 Found Device : 0123456789ABCDEF Checking Root access: True Backup created:C:\NCK Dongle\NCK Dongle Samsung Module\backup\GT-S5360_\bml15_2.bin Unlock Done, Restarting Phone! Total Time: 00:00:18 -------------------------- Log saved to: logs\GT-S5360_unlock__6.txt ...and another one.... Model Selected : GT-S5360 If Phone ask sor SU acces, Allow it. LCD must be ON and unlocked. Found Device : 0123456789ABCDEF MODEL : GT-S5360 BOARD ID : totoro PLATFORM ID : bcm21553 OS VERSION : 2.3.6 BUILD ID : GINGERBREAD BUILD DATE : Wed Jun 27 10:45:25 KST 2012 BUILD VERSION : GINGERBREAD.XXLF3 SOFTWARE VERSION : S5360XXLF3 IMEI : 35424305881XXXX (GSM)RIL VERSION : BRCM android bcm-ril-090728 (GSM)BASEBAND : S5360XXLF3 (RIL)SW VERSION : S5360XXLF3 (RIL)(RIL)HW VERSION : 1.1 Found Device : 0123456789ABCDEF Checking Root access: True Backup created:C:\NCK Dongle\NCK Dongle Samsung Module\backup\GT-S5360_\bml15_3.bin Unlock Done, Restarting Phone! Total Time: 00:00:19 -------------------------- Log saved to: logs\GT-S5360_unlock__7.txt |
12-04-2014, 13:06 | #2629 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | Serial :XXXxxxxxx Active credits: 3.5 Your IP :xx.xx.xxx.xx SERVER RETURN: IMEI: 8695630154XXXXX Unlock Codes: 601581652422XXXX 223442041062XXXX 112001693523XXXX 78116197247XXXX -------------------------- Log saved to: logs\HUAWEI_AllLevels+ResetKey_8695630154XXXXX_log 2.txt |
12-05-2014, 10:22 | #2630 (permalink) |
Freak Poster Join Date: Sep 2014 Location: philippines
Member: 2256970 Status: Offline Thanks Meter: 67 | cloudfone thrill unlock done Scanning for presents meta ports... Meta ports not detected, starting brom stage. Phone must be off with battery inside. Please insert USB cable now... Detected(0) : MediaTek PreLoader USB VCOM Port (COM162) Starting META mode, wait... If drivers missing, please install CDC drivers. META ok, waiting for meta port.... META Port Detected[13] Android Gadget VCOM Driver (COM13) Start sync target, waiting responce..... BaseBand CPU : MT6573, E00 SW_VER : MAUI.11AMD.W11.37.SP.V14.P1 HW_VER : MIKI73_HW Phone imei[1] : 35857202267061 Phone imei[2] : 35857202269061 Start direct unlock[SIM1] Direct unlock done Start direct unlock[SIM2] Direct unlock done Direct unlock done Direct unlock done All done. |
The Following User Says Thank You to Naps For This Useful Post: |
12-06-2014, 09:53 | #2633 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | Alcatel OT-4015x calculated perfectly :) IMEI checksum seems ok Brand: Alcatel android Model: OT-4015X IMEI :8659100220xxxxx Connecting to server please wait... PID: VNRS1 SECRO: X6C0EE01AN10 NCK: 03378133 NSCK: 18014412 SPCK: 18393479 CPCK: 18493430 CCK: 05157419 Calculated by NCKServer. With non accepted simcard , insert code Alternative metod: Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK If code wrong, please dump SECRO with "ANDROID MTK" exe and report in forum. New firmware version can generate wrong code, use cable unlock!!!! -------------------------- Log saved to: logs\AlcatelAndroid_OT-4015X_8659100220xxxxx_codecalculate_1.txt All done |
12-06-2014, 11:44 | #2634 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | alcatel OT1030X calculate unlock code ok Model: OT1030X IMEI: 869792016491633 PID: RGFR3(XW53LCD0) NCK=4246309356 NSCK=1190060634 SPCK=2196377855 SIM=2023228809 CORPORATE=2834160026 -------------------------- Log saved to: logs\OT1030X_RGFR3(XW53LCD0)_869792016491633_1.txt |
The Following User Says Thank You to karim1980 For This Useful Post: |
12-06-2014, 13:31 | #2635 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | Alcatel OT-4033x calctulated ok :) IMEI checksum seems ok Brand: Alcatel android Model: OT-4033X IMEI :8621490249xxxxx Connecting to server please wait... PID: TNRS1 SECRO: X2A0EF01AN00 NCK: 27327190 NSCK: 37180321 SPCK: 36805913 CPCK: 36402526 CCK: 28268948 Calculated by NCKServer. With non accepted simcard , insert code Alternative metod: Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK If code wrong, please dump SECRO with "ANDROID MTK" exe and report in forum. New firmware version can generate wrong code, use cable unlock!!!! -------------------------- Log saved to: logs\AlcatelAndroid_OT-4033X_8621490249xxxxx_codecalculate_1.txt All done |
12-06-2014, 13:36 | #2636 (permalink) |
Member: 1995502 Status: Offline Thanks Meter: 139 | Alcatel OT-1060D direct unlock done :) SELECTED : OT-1060D Start Detect phone. Remove the battery and connect handset to PC via USB cable. After long press "*" key while inserting the battery. Detected: SCI USB2Serial (COM99) Download mode ok. BOOT: SPRD3 Sending loader, wait. BOOT OK: Spreadtrum Boot Block version 1.2 CPU: 6531 Changing Baud. Reading Flash Info, wait... Flash Size: $400000 Fixed NVRAM adress: $3A8000 EFS start adress: $3B0000 PROD_INFO: $3AEC00 Start UNLOCK, wait. Reading NV. NVRAM Size: $62FC Model: 1060D-2AS7RS1 Backup saved: backup\spd_nvram_backup\OT-1060D_352273017386340_saved_nv_1.bin Simlock exists. Write Done. Job done. |
12-07-2014, 19:34 | #2639 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Moldova, Chisinau
Member: 1794924 Status: Offline Sonork: Yahoo - Razlo4ka Thanks Meter: 37 | Direct unlock Tablet Pop 8 with exhausted attempts to enter the code |
The Following User Says Thank You to Den24 For This Useful Post: |
