12-18-2014, 16:32 | #2702 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | HTC SIM UNLOCK done Serial :3004xxxxx Active credits: 0 Your IP :213.230.xx.xx SERVER RETURN: IMEI: 3588500xxxxxxx Unlock Codes: 63979321 -------------------------- |
The Following User Says Thank You to UzUnlocker For This Useful Post: |
12-18-2014, 19:08 | #2703 (permalink) |
Insane Poster Join Date: Jul 2009 Location: poland
Member: 1079440 Status: Offline Thanks Meter: 4 | Serial :1x Active credits: 0 Your IP :xxxxxxxx SERVER RETURN: IMEI: 01233700xxxxxxx Unlock Codes: serialNumber : 7T0262LNA4S partDescription : IPHONE 4 BLACK 16GB-GBR imeiNumber : 01xxxxxxxxxxxxxxx initialActivationPolicyDetails : UK TMobile Orange. initialActivationPolicyID : 302 unlocked : false unlockDate : warrantyStatus : Out Of Warranty (No Coverage) coverageStartDate : coverageEndDate : daysRemaining : 0 PurchaseDate : 07/11/10 purchaseCountry : United Kingdom registrationDate : 07/11/10 productDescription: iPhone 4 nextTetherPolicyID: 302 nextTetherPolicyDetails:UK TMobile Orange. appliedActivationPolicyID:302 appliedActivationDetails:UK TMobile Orange. unbricked : true firstUnbrickDate : 07/11/10 lastUnbrickDate : 07/08/14 meid : iccID : productVersion : 7.1.2 -------------------------- Log saved to: logs\IPHONE_iPhoneFullGSXInfo_xxxxxxxxxxxxxxxxxxxx _log2.txt Hello and here is the information about whether the phone is blacklisted if it is clear and where ??? Last edited by Fast Unlocking; 12-18-2014 at 19:45. |
12-18-2014, 22:28 | #2705 (permalink) | |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,263 | Quote:
The Following User Says Thank You to Fast Unlocking For This Useful Post: |
12-19-2014, 10:41 | #2706 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | another Virgin Mobile VM575 Oneclick unlock done.... SELECTED : VM575 Start Detect phone. Remove the battery and connect handset to PC via USB cable. After long press "*" key while inserting the battery. Detected: SCI USB2Serial (COM26) Download mode ok. BOOT: SPRD3 Sending loader, wait. BOOT OK: Spreadtrum Boot Block version 1.2 CPU: 6531 Changing Baud. Reading Flash Info, wait... Flash Size: $400000 Fixed NVRAM adress: $3B8000 EFS start adress: $3C0000 PROD_INFO: $3BEC00 SIMK: $390000 Start UNLOCK, wait. Pathing simlock area, wait. Write File Done. Job done. -------------------------- Log saved to: logs\VM575_format_4.txt |
The Following User Says Thank You to razib143 For This Useful Post: |
12-19-2014, 10:45 | #2707 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcate OT-4007D Counter block reset and Unlock done by Flash.. Flash files count is :11 Action : Firmware update. [COLOR="rgb(0, 255, 255)"] Selected Alcatel: OT-4007D[/COLOR] Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM19) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6575_S01 NAND: (4Gb+2048Mb) [Micron] NAND_MT29C4G48MAAHBAAKS_5WT BOOT STYLE : NAND BOOT Detecting high speed port, wait...... If driver not installed, install high speed port driver. Detected : MediaTek DA USB VCOM Port (COM20) Send preloader... Download firmware to flash now... UBOOT checksum is executing ... BOOTIMG checksum is executing ... RECOVERY checksum is executing ... SEC_RO checksum is executing ... LOGO checksum is executing ... ANDROID checksum is executing ... CUSTPACK checksum is executing ... USRDATA checksum is executing ... Wait untill phone will start charging. [COLOR="rgb(0, 255, 255)"] All done.[/COLOR] Scanning for presents meta ports... Meta ports not detected, starting brom stage. Phone must be off with battery inside. Please insert USB cable now... Detected(0) : MediaTek PreLoader USB VCOM (Android) (COM19) Starting META mode, wait... If drivers missing, please install CDC drivers. META ok, waiting for meta port.... META Port Detected[95] Android Gadget VCOM Driver (COM95) Start sync target, waiting responce..... BaseBand CPU : MT6575 SW_VER : MAUI.11AMD.W11.50.SP.V31.P2 HW_VER : JRDHZZ75_PIXO_GB2_HW Phone imei[1] : 86134002168349 Phone imei[2] : 86134002168350 Start direct unlock[SIM1] Direct unlock done Start direct unlock[SIM2] Direct unlock done Direct unlock done Direct unlock done Clean Boot flag ok. All done. |
12-19-2014, 14:43 | #2709 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | ***** M727G Unlock done .. Quote:
12-19-2014, 14:44 | #2710 (permalink) | |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | Alcatel 4007D Unlock done .. Quote:
12-19-2014, 18:28 | #2712 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | HTC 310 Unlock code read done in meta mode... Scanning for presents meta ports... Detected(497) : MediaTek DA USB VCOM (Android) (COM497) Skipping brom stage, meta port found. Start sync target, waiting responce..... BaseBand CPU : MT6582, E01 SW_VER : MOLY.WR8.W1315.MD.WG.MP.V19.F4.P6 HW_VER : CCI82_WET_LX83_JB5_HSPA_HW Meta mode conected ok, start reading phone.... Phone imei[1] : 35191206644175 Phone imei[2] : 35191206644175 Simlock Info : Sim [1] Block1[N] :Locked [remain:11] Code : 01329768 Block2[NS] :Unlocked Code: 56781234 Block3[SP] :Unlocked Code: 11112222 Block4[C] :Unlocked Code: 33334444 Block5[SIM]:Unlocked Code: 55556666 ************************************** Simlock Info : Sim [2] Block1[N] :Unlocked Code : 12345678 Block2[NS] :Unlocked Code: 56781234 Block3[SP] :Unlocked Code: 11112222 Block4[C] :Unlocked Code: 33334444 Block5[SIM]:Unlocked Code: 55556666 ************************************** 1.Power phone with unacepted simcard. 2.Type code code when phone ask about. 3.For advansed info power phone with original card. 4.Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK If phone relock after power off, enter unlock code and make wipe. All done. |
12-20-2014, 11:51 | #2715 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | ZTE Blade perfectly calculated IMEI checksum seems ok Brand: ZTE Android Model: BLADE IMEI: 35316004263xxxx NCK=80387933 NCK(B04)=13727101 -------------------------- Log saved to: C:\Documents and Settings\Admin\My Documents\NckDongle\Logs\35316004263xxxx_BLADE1.tx t All done |
