02-19-2013, 08:20 | #1036 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: Pilipinas
Member: 757159 Status: Offline Thanks Meter: 467 | Quote:
02-19-2013, 11:55 | #1037 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Philippines Age: 34
Member: 1352605 Status: Offline Thanks Meter: 45 | Docomo SO-01B Unlock Done By NCK-Box Code: Unlock procedure started, waiting for phone. Power off phone, keep BACK button and insert usb cable. Keep holding back key untill next prompt. Connecting to the server Please wait.... Send S1 Loader Loader is sent, please wait... Read device info. CXC : 1226-2250 IMEI : 35949603878252 EROM AID : 0001 LOADER AID : 0001 AID TAMP STATE : NOT_TAMPERED SE X10 GROUP - HOLD THE BACK KEY IMEI : 35949603878252 - SE UNLOCK STARTED (X10 group). - WAITING USER ACTION - WAITING PHONE Version : 2.1-update1 OK. - PHONE FOUND - ROOT ACCESS OK Changes made... Verifing new data, cant take up to 1min, do not tuch phone! - STATUS: - UNLOCKED! Wait untill phone full power on. -------------------------- Log saved to: logs\35949603878252_DocomoSO-01B_1.txt |
The Following User Says Thank You to TeamGsm For This Useful Post: |
02-20-2013, 05:20 | #1038 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | Quote:
02-20-2013, 12:19 | #1039 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | BlackBerry 9900 unlocked done.... Code: IMEI:351504051778625 is ok Connecting to server please wait... PRD : PRD-39472-039 Imei : 351504051778625 MEP1 :2517952759294890 MEP2 :4122921911145219 MEP3 :3352790833388613 MEP4 :6465856698738054 MEP5 :1948098473654581 |
02-20-2013, 13:46 | #1040 (permalink) |
Insane Poster Join Date: Aug 2008 Location: Hungary Age: 41
Member: 830047 Status: Offline Thanks Meter: 6 | COM : 149 Selected Model Selected : GT-S5830 Start Reading Info.. Model : GT-S5830 Product code : S5830XWKB4 Version : S5830XWKB4/S5830TMHKB1/S5830XXKA6 Imei : 35765504894... Bypass MSL Need... Scaning Security Area... Bypass MSL done.. Start Direct Unlocking.. Direct Unlock done . -------------------------- Log saved to: logs\GT-S5830_unlock.doc |
02-20-2013, 17:02 | #1041 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Romania Age: 46
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | AndroidMtk ;OT-991 read codes ok Code: Phone must be off with battery inside. Please insert USB cable now... Phone detected, switch to meta mode, wait.... This can take up to 30 sec, do not disconnect phone. Meta mode conected ok, start reading phone.... Phone imei : 8626010******* ..........Simlock Info............ Block1(N ):Locked (remain:2) Code : 40376314 Block2(NS):Unlocked Code: 24481898 Block3(SP):Unlocked Code: 26161510 Block4(C ):Unlocked Code: 40788318 Block5(SIM):Unlocked Code: 35158295 1.Power phone with unacepted simcard. 2.Type code code when phone ask about. 3.For advansed info power phone with original card. 4.Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK |
02-21-2013, 06:51 | #1042 (permalink) |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | xperia x8 E15i unlocked successfully Unlock procedure started, waiting for phone. Power off phone, keep BACK button and insert usb cable. Keep holding back key untill next prompt. Connecting to the server Please wait.... Send S1 Loader Loader is sent, please wait... Read device info. CXC : 1229-3641 IMEI : 01256xxxxxxxxxx EROM AID : 0001 LOADER AID : 0001 AID TAMP STATE : NOT_TAMPERED SE X8 GROUP - HOLD THE BACK KEY IMEI : 01256xxxxxxxxxxx - SE UNLOCK STARTED. - WAITING USER ACTION - WAITING PHONE Version : 2.1-update1 OK. Start comunication with phone... - WAITING PHONE - PHONE FOUND Changes appilied Check changes, wait.. Wait untill phone full power on. - STATUS: - UNLOCKED!! Wait untill phone full power on. -------------------------- |
02-21-2013, 10:24 | #1043 (permalink) |
Freak Poster Join Date: Apr 2011 Location: iloilo city
Member: 1561609 Status: Offline Thanks Meter: 9 | Samsung S5360 unlock done Model Selected : GT-S5360 Found Device : 0123456789ABCDEF MODEL : GT-S5360 BOARD ID : totoro PLATFORM ID : bcm21553 OS VERSION : 2.3.6 BUILD ID : GINGERBREAD BUILD DATE : Fri Nov 25 08:33:16 KST 2011 BUILD VERSION : GINGERBREAD.DXKK4 SOFTWARE VERSION : S5360DXKK4 IMEI : 359961043712900 (GSM)RIL VERSION : BRCM android bcm-ril-090728 (GSM)BASEBAND : S5360DXKK2 (RIL)SW VERSION : S5360DXKK2 (RIL)(RIL)HW VERSION : MP 0.700 Found Device : 0123456789ABCDEF Checking Root access: True Backup created..c:\NckBox\\temp\samsung_backup\GT-S5360_359961043712900\bml15 Unlock Done, Restarting Phone! |
The Following 2 Users Say Thank You to nonoy_agi For This Useful Post: |
02-21-2013, 20:05 | #1044 (permalink) |
No Life Poster Join Date: Aug 2011 Location: United Kingdom
Member: 1638915 Status: Offline Thanks Meter: 432 | successfully unlocked sony ericsson xperia X8 Via NCK BOX successfully unlocked sony ericsson xperia X8 Via NCK BOX 1.JPG 2.JPG Unlock procedure started, waiting for phone. Power off phone, keep BACK button and insert usb cable. Keep holding back key untill next prompt. Connecting to the server Please wait.... Send S1 Loader Loader is sent, please wait... Read device info. CXC : 1229-3641 IMEI : 01256000643426 EROM AID : 0001 LOADER AID : 0001 AID TAMP STATE : NOT_TAMPERED SE X8 GROUP - HOLD THE BACK KEY IMEI : 01256000643426 - SE UNLOCK STARTED. - WAITING USER ACTION - WAITING PHONE Version : 2.1-update1 OK. Start comunication with phone... - WAITING PHONE - PHONE FOUND Changes appilied Check changes, wait.. Wait untill phone full power on. - STATUS: - UNLOCKED!! Wait untill phone full power on. -------------------------- Log saved to: logs\01256000643426_XperiaX8E15i_1.txt 3.JPG 4.JPG |
The Following 3 Users Say Thank You to bux_harun For This Useful Post: |
02-22-2013, 12:21 | #1045 (permalink) |
Member: 237155 Status: Offline Thanks Meter: 415 | galaxy i9003 unlock done by gr8 nck dongle. (ADB)Model Selected : GT-I9003 Found Device : 900337b49026 MODEL : GT-I9003 BOARD ID : GT-I9003 PLATFORM ID : omap3 OS VERSION : 2.2.1 BUILD ID : FROYO BUILD DATE : Tue Feb 15 17:18:12 KST 2011 BUILD VERSION : FROYO.BGKB3 SOFTWARE VERSION : I9003BGKB3 IMEI : 3549xxxxxxxxxxxxxx (GSM)RIL VERSION : Samsung RIL(IPC) v2.0 (GSM)BASEBAND : I9003XXKB1 (RIL)SERIAL NUMBER : 00000000000 (RIL)SALES CODE : XEC (RIL)SW VERSION : I9003XXKB1 (RIL)(RIL)HW VERSION : MP 1.000 Found Device : 900337b49026 Checking Root access: False Uploading Exploit data.. Rooting phone please Wait. Waiting For Phone To Reply IF THIS TAKE LONG Then Reconnect Phone Cable And Verify Driver... Checking Root access: True EFS PARTITION PRESENT. Backup saved : c:\nck_dongle\\samsung_backup\GT-I9003_00000000000\ Unlock Done, Restarting Phone! |
02-23-2013, 13:44 | #1046 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Hungary Age: 48
Member: 141809 Status: Offline Thanks Meter: 30 | Samsung SS5570 unlock ok ! Code: Model Selected : GT-S5570 Start Reading Info.. Model : GT-S5570 Product code : S5570XWKQG Version : S5570XWKQG/S5570TMHKQ1/S5570XWKQ5 Imei : 351xxxxxxxxxxx Bypass MSL Need... Scaning Security Area... Bypass MSL done.. Start Code Reading... **************************** Unfreeze(MCK) : 74285080 NCK : 04084736 NSCK : Unknown SPCK : Unknown CPCK : Unknown **************************** -------------------------- |
02-23-2013, 13:48 | #1047 (permalink) |
Member: 141809 Status: Offline Thanks Meter: 30 | SE X8 unlock ok ! Code: Unlock procedure started, waiting for phone. Power off phone, keep BACK button and insert usb cable. Keep holding back key untill next prompt. Connecting to the server Please wait.... Send S1 Loader Loader is sent, please wait... Read device info. CXC : 1229-3641 IMEI : 0124xxxxxxxxxx EROM AID : 0001 LOADER AID : 0001 AID TAMP STATE : NOT_TAMPERED SE X8 GROUP - HOLD THE BACK KEY IMEI : 0124xxxxxxxxxx - SE UNLOCK STARTED. - WAITING USER ACTION - WAITING PHONE Version : 2.1-update1 OK. Start comunication with phone... - WAITING PHONE - PHONE FOUND Changes appilied Check changes, wait.. Wait untill phone full power on. - STATUS: - UNLOCKED!! Wait untill phone full power on. |
02-24-2013, 06:15 | #1048 (permalink) |
No Life Poster Join Date: Jun 2011 Location: manila
Member: 1595088 Status: Offline Thanks Meter: 184 | Model Selected : GT-S5360 Found Device : 0123456789ABCDEF MODEL : GT-S5360 BOARD ID : totoro PLATFORM ID : bcm21553 OS VERSION : 2.3.6 BUILD ID : GINGERBREAD BUILD DATE : Thu Jan 12 20:25:01 KST 2012 BUILD VERSION : GINGERBREAD.DXLA1 SOFTWARE VERSION : S5360DXLA1 IMEI : 351863054737305 (GSM)RIL VERSION : BRCM android bcm-ril-090728 (GSM)BASEBAND : S5360DXLA1 (RIL)SW VERSION : S5360DXLA1 (RIL)(RIL)HW VERSION : MP 0.701 Found Device : 0123456789ABCDEF Checking Root access: True Backup created..c:\NckBox\\temp\samsung_backup\GT-S5360_351863054737305\bml15 Unlock Done, Restarting Phone! -------------------------- Log saved to: logs\GT-S5360_adbunlock_2.txt thank you |
The Following User Says Thank You to tartcell18 For This Useful Post: |
02-26-2013, 12:55 | #1049 (permalink) |
No Life Poster Join Date: May 2007 Location: Islamic city of Marawi
Member: 502507 Status: Offline Sonork: 100.1648947 Thanks Meter: 154 | Now connect phone to PC Injecting Loader.. Reconnecting phone, this can take few second.. Loader started ok. Reading Phone Info, please wait.. Phone Imei : 353026043276888 Phone SN : 7XA7NC1210606790 Phone Firmware : U8500V100R001C00B718_EFS SimLock marker found.. Total markers found : 1 Simlock Status : Locked. Removing SimLocks Please Wait... Read marker : 1 Write marker : 1 All Done. If Phone not have network after unlock, use fix network please. |
