02-17-2022, 14:07 | #857 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Nck can flash any factory pac file, including cpu sc7731e also. Last edited by orbita; 02-17-2022 at 14:13. |
The Following 2 Users Say Thank You to orbita For This Useful Post: |
03-03-2022, 09:10 | #858 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | vivo v21 v2050 5g android 12 CPU: mt6853 Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 2.9.7 Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(70) : MediaTek USB Port_V1633 (COM70) [70] \\?\usb#vid_0e8d&pid_0003#6&a8b0b49&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: mt6853 CPU code: 996 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone [-5]error usb_control_msg libusb0-dll:err [control_msg] sending control message failed, win error: A device attached to the system is not functioning. Exploit has been not executed. Posible unsupported phone. |
03-03-2022, 17:25 | #860 (permalink) |
Freak Poster Join Date: Nov 2018 Location: Everywhere Your Not
Member: 2875052 Status: Offline Thanks Meter: 211 | ZTE Blade A31 Unlock Done Spreadtrum 9863a_3h10 Board First 16 bytes from public rsa key. B8928F81E592DF02E227A84968366708 *************** Phone Storage: EMMC EXE: NckBox Spreadtrum Module 2.1.1 SELECTED: SC9863A_EMMC_ZTE([sign 1]A10+) ACTION: SimUnlock Loader format:NEW Start Detect phone. Phone must be off with battery inside. Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM9) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. UID: TCWP61_10_7_16 *************** [S]Manufacturer: ZTE [S]Brand: ZTE [S]Device: P963F70 [S]Model: ZTE Blade A31 Build ID: RP1A.201005.001 CPU arhitecture: armeabi-v7a Build product name: s9863a1h10_go_32b Build description: s9863a1h10_go_32b_general-user 11 RP1A.201005.001 20210717.125738 release-keys Product name: P963F70_1 SW Version: FLOW_JM_P963F70V1.0.0B02 Board: s9863a1h10_go_32b Build Id: RP1A.201005.001 Android Release: 11 Android Version: FLOW_JM_A31_V1.0 Security patch: 2021-07-05 CPU NAME: SC9863A NV partition: l_fixnv1_a IMEI 1: 864210053679460 IMEI 2: 867400020316620 IMEI 3: 867400020316638 IMEI 4: 867400020316646 Simlock Type: 4 Simlock Status: SIMLOCK: ACTIVE NETWORK SUBNET: INACTIVE SP LOCK: INACTIVE CORPORATE: INACTIVE USER LOCK: INACTIVE [4]Simlock Type: 0 0 Backup saved to: C:\Users\Valued Customer\Documents\spreadtrum_module\flashmode_nvr am_backup\FLOW_JM_A31_V1.0_s9863a1h10_go_32b\FLOW_ JM_A31_V1.0_s9863a1h10_go_32b_nvram_backup.tar Testing key 1 Testing key 2 Testing key 3 Sim unlock and repair imei is supported for this phone. Integrity seems ok, proceed with unlock.... Start write unlock, wait... [can take 0-10 sec]Wait untill phone restart. Log saved: C:\Users\Valued Customer\Documents\spreadtrum_module\Saved_Logs\FL OW_JM_A31_V1.0_864210053679460_867400020316620_sim _unlock_phone.txt Total Time: 00:00:39 Done. |
05-27-2022, 04:24 | #861 (permalink) |
Junior Member Join Date: Sep 2015 Location: Port-au-Prince, Haiti
Member: 2454107 Status: Offline Sonork: spunlock00 Thanks Meter: 0 | sky elite octa x not unlock I got this message while unlocking:" Exception[SPD_ALGO_DIAG_UNLOCK_SIMLOCK]" could you help me please? |
05-27-2022, 21:21 | #862 (permalink) | |
Junior Member Join Date: Jul 2017
Member: 2740428 Status: Offline Thanks Meter: 0 | Nokia and samsung Quote:
Samsung A models | |
06-28-2022, 09:30 | #867 (permalink) |
Freak Poster Join Date: Dec 2015 Location: Kumasi,Ghana
Member: 2496301 Status: Offline Thanks Meter: 41 | Calypso (U318AA) Exe version: NCKBox AndroidMTK 2.9.7 Selected model: 0-By CPU MT6739 Action: Unlock Phone must be off with battery inside. Battery must be charged Please connect phone in brom mode For some phones need to keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(23) : MediaTek USB Port_V1633 (COM23) [23] \\?\usb#vid_0e8d&pid_0003#5&101738c0&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6739 CPU code: 699 Target config: e7 *********************** Secure boot enabled: true Need serial link authorization: true Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [1ec00]Dumping phone preloader. Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader _backup\preloader_u318.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(23) : MediaTek USB Port_V1633 (COM23) [23] \\?\usb#vid_0e8d&pid_0003#5&101738c0&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6739 0 ca00 Using Algo 1. Helio MT6739 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6739 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010046453632 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(10) : MediaTek DA USB VCOM (Android) (COM10) [10] \\?\usb#vid_0e8d&pid_2001#5&101738c0&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Modem version: MOLY.LR12A.R3.MP.V107.4.P20 IMEI[1]: 864**********22 IMEI[2]: 0000000000000000 Reading security, wait... [1]Unlock is not supported for this model [helio]Wait untill phone will start charging. [0]All done. |
