06-11-2020, 21:02 | #1 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | tecno ca8 dead after try to flash [ANSWERED] [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A48434738 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe90400000 [58.254 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM69) Starting flash helio. SGPT PGPT [0] WRITE TO PARTITION [ preloader ] [3] WRITE TO PARTITION [ recovery ] Error[0xc0030008]: STATUS_INVALID_GPT [helio]Wait untill phone will start charging. [0]All done. |
06-12-2020, 14:31 | #3 (permalink) | |
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | help Quote:
Action : Firmware update. Selected Model: Tecno: CA8 Exe version: NCKBox AndroidMTK 2.4 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM12) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6763 1 ca01 Using Algo 3. Helio MT6763 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE BBCHIP MT6763 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A48434738 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe90400000 [58.254 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM69) Starting flash helio. SGPT PGPT [3] WRITE TO PARTITION [ recovery ] Error[0xc0030008]: STATUS_INVALID_GPT [helio]Wait untill phone will start charging. [0]All done. Action : Boot Info. Selected Tecno:CA8 Exe version: NCKBox AndroidMTK 2.4 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM12) Boot mode: Preloader Phone detected...Please wait BBCHIP: 6763 1 ca01 Using Algo 3. Helio MT6763 phone detected, swithing to helio api Helio enabled DRAM in First Da: TRUE BBCHIP MT6763 [1]Storage EMMC EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A48434738 : 000000000000000000 EMMC UA SIZE: 0xe8f800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe90400000 [58.254 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM69) Partition entry is empty. [helio]Wait untill phone will start charging. [0]All done. | |
06-12-2020, 14:41 | #4 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Based on your log can be one from this what cause this problem. 1.Your exe is very old and can cause problem. How to fix: Update your exe to latest version. 2.Your firmware can be wrong or incompatible How to fix: Find compatible firmware 3.Phone can have hardware problem How to fix: Perform hardware repair. Also can be bad cable, discharged battery e.t.c. But this most posible you check already. |
