03-05-2021, 10:25 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | You can download firmware from support. You can flash this phone as any other qualcomm, from edl mode. With phone off, keep vol- and vol+ pressed and insert usb cable. After follow hints from phone screen. |
The Following User Says Thank You to orbita For This Useful Post: |
03-07-2021, 11:20 | #5 (permalink) |
No Life Poster Join Date: Aug 2007 Location: earth
Member: 570373 Status: Offline Thanks Meter: 230 | flash fail Exe Version: NckBox Qualcomm Module 0.12.8 Operation: Read Info Searching for phone..... Qualcomm HS-USB QDLoader 9008 (COM4) detected. Hello received. HW ID: 11004200E1507000 MSM8916 PK HASH: 625801C51EEE90D7F0E0EDB1606BB07E05871BD24F69F3FADF D17FDCE0D4B4F0 Checking database for suitable loader..... Arhitecture:32 bits [32]Sending loader, please wait.. Waiting for loader to start... [1] Send NOP ok, loader start. CPU: MSM8916 MaxPayloadSizeFromTargetInBytes: 4096 MaxPayloadSizeToTargetInBytes: 8192 Reading partition info, wait. Volume[0] Size: 7.28 GB Partitions count: 36 [00A5F38F]Userdata Size: 5.19 GB Manufacturer: Vodafone Cpu: armeabi-v7a Build Id: LRX22G Model: VF-895N Android Release: 5.0.2 Android Version: LRX22G release-keys Config: diag,serial_smd,rmnet_bam,adb IMEI: 35690 Model: V895N-2HVDGB2 Secro: X9W7FCN0BG00 Restarting phone..... ************************************* Exe Version: NckBox Qualcomm Module 0.12.8 Operation: Download Searching for phone..... Qualcomm HS-USB QDLoader 9008 (COM4) detected. Hello received. HW ID: 11004200E1507000 MSM8916 PK HASH: 625801C51EEE90D7F0E0EDB1606BB07E05871BD24F69F3FADF D17FDCE0D4B4F0 Checking database for suitable loader..... Arhitecture:32 bits [32]Sending loader, please wait.. Waiting for loader to start... [1] Send NOP ok, loader start. CPU: MSM8916 MaxPayloadSizeFromTargetInBytes: 4096 MaxPayloadSizeToTargetInBytes: 8192 Reading partition info, wait. Volume[0] Size: 7.28 GB Partitions count: 36 [00A5F38F]Userdata Size: 5.19 GB [0]Writing: modem Start: 131072 length: 105699 [0]Error read repply xml <?xml version="1.0" encoding="UTF-8" ?><data><response value="NAK" rawmode="false" /></data> Error repply end block Error untill writing: NON-HLOS.bin Restarting phone..... ************************************* |
03-07-2021, 11:29 | #6 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Phone is old, so try to dissasemble phone and check for water or other damages. Also try to resolder flash ic, most posible bad contacts or damaged flash ic cause stuck on logo. |
09-04-2021, 10:53 | #9 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Not need to confuse users, if you not know how to use some, this not meen it not work. 32 bit drivers will not work for 64 bit version of windows. Need to use right drivers, according to your windows version. In support you can find drivers for 32 and 64 version. Last edited by orbita; 09-04-2021 at 11:10. |
