11-26-2020, 15:25 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 595179 Status: Offline Thanks Meter: 2 | x655 dead after flash no imei no baseband try to restore nv and no result its run with this rom X655-H6210ABFG-Q-OP-200904V258 i try flash but its dead it requir auth file i try flash via all tool and many roms it sust driver Mediatek USB Port_V1633 (com... log Flash files count is :26 Action : Firmware update. Selected Model: 0-By CPU: ELBRUS Exe version: NCKBox AndroidMTK 2.9.1 Scenario: [0]Safe Flash Will be used loader: MTK_AllInOne_DA.bin Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port_V1633 (COM20) Boot mode: Brom Brom stage DA fail, aborting [STATUS_SEC_AUTH_FILE_NEEDED][AUTH]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model Or load auth file manually in exe Boot Fail.!!!. [0]All done. any solution?? |
11-28-2020, 07:45 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | If you erased preloader in your phone you have 2 posible solutions. 1.Find auth file and write back preloader in phone. 2.Desolder flash ic and write preloader direct with some emmc tool. |
