02-02-2023, 16:30 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: tropical island
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | zte blade a31 unlock failed [ANSWERED] B8928F81E592DF02E227A84968366708 *************** Phone Storage: EMMC SELECTED: SC9863A_EMMC_ZTE([sign 1]A10+) ACTION: SimUnlock Loader format:NEW Start Detect phone. Phone must be off with battery inside. Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM22) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. Read partition info is supported by loader. UID: TCUS29_21_24_28 *************** [S]Manufacturer: ZTE [S]Brand: ZTE [S]Device: P963F70 [S]Model: ZTE Blade A31 Build ID: RP1A.201005.001 CPU arhitecture: armeabi-v7a Build product name: s9863a1h10_go_32b Build description: s9863a1h10_go_32b_general-user 11 RP1A.201005.001 20210717.125738 release-keys Product name: P963F70_1 SW Version: FLOW_JM_P963F70V1.0.0B02 Board: s9863a1h10_go_32b Build Id: RP1A.201005.001 Android Release: 11 Android Version: FLOW_JM_A31_V1.0 Security patch: 2021-07-05 CPU NAME: SC9863A NV partition: l_fixnv1 IMEI 1: 864210053524427 IMEI 2: 867400020316620 IMEI 3: 867400020316638 IMEI 4: 867400020316646 Simlock Type: 4 Simlock Status: SIMLOCK: ACTIVE NETWORK SUBNET: INACTIVE SP LOCK: INACTIVE CORPORATE: INACTIVE USER LOCK: INACTIVE [4]Simlock Type: 0 0 NV partition: l_fixnv2_a Backup saved to: C:\Users\Genius\Documents\spreadtrum_module\flashm ode_nvram_backup\SC9863A_FLOW_JM_A31_V1_0_86421005 3524427_867400020316620_l_fixnv1_nvram_backup_2.ta r Testing key 1 Testing key 2 Testing key 3 Sim unlock and repair imei is supported for this phone. Integrity seems ok, proceed with unlock.... Start write unlock, wait... Wrong responce. [can take 0-10 sec]Wait untill phone restart. Exe version: NckBox Spreadtrum Module 2.1.7 Log saved: C:\Users\Genius\Documents\spreadtrum_module\Saved_ Logs\FLOW_JM_A31_V1_0_864210053524427_867400020316 620_sim_unlock_phone_2.txt Total Time: 00:00:28 Done. |
02-02-2023, 19:57 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | This phone unlock must be supported by exe. https://forum.gsmhosting.com/vbb/f80.../#post14490156 Check if phone is charged, check usb cable so on. You can try also unlock in diag mode using custom UID and use UID from your above log: TCUS29_21_24_28 |
02-02-2023, 21:40 | #3 (permalink) |
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | everything is working in the log it say wrong response y it say the and when i try diag mode i only see sprd u2s diag port i see look at logs ACTION: Read Info. Detecting phone, wait... error open: COM22 Device not detected, aborting..... Done. Exe version: NckBox Spreadtrum Module 2.1.7 Log saved: C:\Users\Genius\Documents\spreadtrum_module\Saved_ Logs\__read_info_1.txt |
02-02-2023, 21:50 | #5 (permalink) |
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | ACTION: Direct Unlock Detecting phone, wait... Using connection mode 1 Detected: SPRD U2S Diag (COM18) Platform Version: MOCORTM_20A_W20.47.1_P13_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W20.47.1_P13 HW Version: sc9863A_modem 06-26-2021 04:43:12 Build number: FLOW_JM_P963F70V1.0.0B02 EMMC DDR SIZE :29.00 GB+1.00 GB UID: c3b52e5cfe8c28fae9e879526450ed1a97c8ad58b3c0fd33e4 04bafbd7d2ef71 Will be used custom UID: TCUS29_21_24_28 IMEI 1: 864210053524427 IMEI 2: 867400020316620 IMEI 3: 867400020316638 IMEI 4: 867400020316646 BT: F8A34FD0F208 WIFI: C8EAF8B675A8 Reading simlock backup, wait.... Saved to: C:\Users\Genius\Documents\spreadtrum_module\diag_n vram_backup\FLOW_JM_P963F70V1_0_0B02_8642100535244 27__diag_simlock_nvram_backup_1.tar Simlock Status: SIMLOCK: ACTIVE NETWORK SUBNET: INACTIVE SP LOCK: INACTIVE CORPORATE: INACTIVE USER LOCK: INACTIVE Testing key 1 Testing key 2 Testing key 3 Sim unlock and repair imei is supported for this phone. Unlock is supported for this phone Simlock Type: 4 Collecting info from phone.. Checking simlock integrity.... Integrity seems ok, proceed with unlock.... Writing simlock ok Writing simlock sign ok Done. Exe version: NckBox Spreadtrum Module 2.1.7 Log saved: C:\Users\Genius\Documents\spreadtrum_module\Saved_ Logs\FLOW_JM_P963F70V1_0_0B02_864210053524427_diag _simlock_unlock.txt |
The Following User Says Thank You to headszone1 For This Useful Post: |
