Blade A520 FRP RESET Done !!! Blade A520 FRP RESET Done TESTED Android 7 1. Download File https://ufile.io/31sa8 2. Run SP_Flash_Tool_exe_Windows_v5.1712.00.000 3. Load the file 4 Go to Format 5. Select manual format flash - and write in begin adress 0x6a80000, and in the second (format length) 0x100000. Press the start button. We connect the switched off device - we wait for green ОК. http://s008.radikal.ru/i305/1708/05/114173a83bbd.jpg http://s018.radikal.ru/i517/1708/9e/f297b08c70da.jpg |
everybody try this and sucess? |
File For Reset FRP Download New Link 4Shared: https://www.4shared.com/rar/eOiOdwRj...Reset_FRP.html |
Thank you. Perfect solution! |
I try already but still can’t open FRP lock |
1 Attachment(s) no working...got other solution? |
Enviado desde mi CAM-L03 mediante Tapatalk |
Thanks , work for my ZTE Blade A520... |
Someone has the Driver to connect the ZTE Blade A520 to FlashTool .. Thanks friends. |
in my case holding both volume + and volume - together and then connecting the phone worked ... might help someone ... br |
Volume - and insert cable -work |
Thanx, worked with volume down and insert cable... |
I got message "enable dram failed" Hint: "Please chek your load matches to your target which is to be downloaded" I'm trying to link files from the link above. |
Hint: "Please chek your load matches to your target which is to be downloaded" |
thank you so much for share this file, i tryed with many box,dongle and special frp tool but not success after that search in forum than found your post and work like a boooom :) thanks again. |
