ZTE General ZTE phones discussion, firmwares, solution, help |
02-06-2017, 08:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2012 Location: italy
Member: 1825965 Status: Offline Thanks Meter: 874 | root for VDF600 I try root for vdf600 (vodafone / zte) Android 6.0.1, already tried Kingo root, iroot, srsroot but do not work. I found supersu but I could not find any recovery (TWRP) to flash. anyone have any idea where to download? thanks |
02-06-2017, 08:51 | #2 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Try kingroot latest apk. It will not succeed for first time but do it again. Make sure you visit ztedevice site for firmware just in case. All is on your risk anyway. Make sure you enable OEM unlock and keep it unlocked all the time. BR |
The Following User Says Thank You to maremestera For This Useful Post: |
02-08-2017, 16:30 | #4 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2682503 Status: Offline Thanks Meter: 2 | solution found hi. i've the same problem...frp blocked and after a lot of tests i've find the way to unlock the phone. if u are interested i'll write the guide. but for root i'm still looking forward... |
02-09-2017, 16:19 | #6 (permalink) |
Member: 2682503 Status: Offline Thanks Meter: 2 | ok thanks. i'm italian and i've to write the guide (it's a little bit long) and after that translate all in english and be sure that is all right. i'll do this in the weekend when i've spare time because i want make also a video for youtube. be patient please. thanks to all. FOR ROOT i've make it with THE LAST UPDATE of kingroot app from playstore. AND ROM UK1B |
The Following User Says Thank You to dd87 For This Useful Post: |
02-09-2017, 17:09 | #7 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 874 | im italian too me .. my problem is found and make root from recovery so ,i need correct twrp and supersu . this phone is FRP blocked i don't can go on play store for firmware already have this version , uk1b. thanks anyway |
02-10-2017, 18:03 | #8 (permalink) |
Member: 2682503 Status: Offline Thanks Meter: 2 | i've also the recovery twrp good for vdf600. if u want i'll send it to you. i've tried to send u a private message but maybe i don't have a permission to send private message in this forum. |
03-01-2017, 15:57 | #10 (permalink) |
Member: 2682503 Status: Offline Thanks Meter: 2 | sorry for my long delay...but i was out of italy for work. here is the guide: How to Bypass FRP Lock (Google Account Verification) during device setup Power On your FRP locked phone and connect it to a WiFi network from one of the setup screens. └ Tip: If you can get another Android phone in hand, then creating a WiFi hotspot from it would be more convenient for you because the trick involves killing off the WiFi network at a specific time. Once connected to a WiFi network, hit NEXT, and as soon as it says Checking for updates, kill off the WiFi network (turn off your WiFi modem or WiFi hotspot). You’ll get to the screen where you’ve to put in your First and Last name. └ I may take a couple of tries to get to the “Name” screen. Keep trying.. One the Name screen, hit NEXT. You’ll get to the “Protect your phone” screen, here set up a PIN, pattern or password. Now once you’re on the Google services screen, scroll to the bottom of the screen, then switch ON your WiFi network (or WiFi hotspot), and then select/tap on the “Google Terms of Service and Privacy Policy” link. On policies page that opened in a pop-up window, highlight any text/word by holding it, and then select the Share option from the tooltip. From the list of sharing options available, press and hold on the Gmail app icon, you’ll get the Gmail app info page. On Gmail app info page, select Notifications » App settings » then tap the 3 dots options menu and select Manage accounts from there. └ This step might be different for users not running Android 6.0 Marshmallow and above Android releases. On the device settings page, select Google » Search & Now » Now cards » toggle Show cards switch » hit NO THANKS and you’ll get to the Google Search screen. On the Google search screen, type Chrome and open the Chrome browser app from the suggested list. On the Setup Chrome screen, hit NO THANKS, then OK, GOT IT, and the type the following URL in the browser bar: *******/frplock From the URL above, you’ll download the Quick Shortcuts app. Once downloading begins, go back to Now cards screen by hitting the Back button on your device. Here again toggle Show cards switch » hit NO THANKS and get to the Google Search screen » now type Downloads and open the Downloads app. On the downloads app, your download Quick Shortcuts app .apk file should be available. Click on the apk » you’ll get Install blocked screen, hit SETTINGS » scroll down a bit and turn on “Unknown Sources” toggle » hit the back button » open the Quick Shortcuts apk again from the downloads screen » install the app » and Open it once installation is done. Once Quick Shortcuts app is opened, search for “Google Account Manager” and tap on it, you’ll get a dropdown list of activities » select “Type Email and Password” activity (sometimes is double,so you have do the samething in eachother) » hit Try and you’ll get to the re-type password screen » here, hit the 3-dot option menu and select “Browser sign-in”, you’ll get a browser Google sign-in screen. Login with your preferred Google Account, and once signed-in, you’ll get back to the Quick Shortcuts app. Now go all the way back to the device Settings page by hitting the Back button. On the Settings page, sincronize your google account and in the and reboot your phone. Now select “Backup & Reset” » select “Factory Data Reset” » select “RESET PHONE” » Confirm your PIN, Password or Pattern lock » select “ERASE EVERYTHING”. Your device will now factory reset itself. Now once your device boots back, set it up and login using the same Google account that you used in Step 16 above. That’s all. Hope this guide helps you bypass FRP lock and Google Account Verification on your Android device. |
