ZTE General ZTE phones discussion, firmwares, solution, help |
03-13-2017, 22:35 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | [Guide] ZTE Avid Plus Z828 FRP Removed Solution Here Video Guide 1. Go through the setup until you get to the google verifying part. 2. Open up your keyboard and hold down the comma to access the gear which will allow you to get into the google keyboard settings. 3. Once you're at the google keyboard settings go to Text Correction. 4. Then go to Personal Dictionary and select English (US) or whatever you have there. 5. Then click on the search button and just type random letters and hit search is what i did to get to this next step. 6. You should be able to type in the letter "g" and you should see something called Google voice typing 7. Click that and go to Text-to-speech. 8. Then click the blue gear next to google text to speech 9. Click install voice data 10. You should see 3 dots on the top right hand corner open that and click open source licenses 11. once you're at this part just simply hold a line down as if you were going to copy it. 12. You should see about 4 options on what you want to do with that line like copy or share it search it on the web. 13. What you want to do is click search, its the fourth option. 14. Delete whatever is on the search and type in settings the option to access the settings should pop up on the bottom as a suggestion. 15. Click that and now you're at the settings. From here on i assume you know how to access the about phone and turn on developer settings but this is the problem you can turn it on but you cant access the developer menu you can just click it and nothing will happen. Same for trying to reset the phone from the back up and reset menu. If anybody knows what the case may be please let me know i'm constantly trying to find the solution to this whenever i have the free time but so far no solution has came up. I'M able to download apks by instead of typing in settings on the google search i type in file manager and simply transfer over the apk through my pc onto the phone. That i can do without usb debugging because my pc picks the phone up as a portable device. Credit Goes ==> XDA
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 12 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
03-14-2017, 01:24 | #2 (permalink) |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | Try this First download quick shortcut maker.apk copy to the phone , open the keyboard, go to settings look for text to speech options,Google text to speech engine, click on the settings img, install voice data,open source license press and select one text...click on the lens look for file manager open and install the quickshortcut.apk open and find Google account manager,open the service and look where says error,open the service click on the 3 points menu and go to browser signing use your account and restart...is done Last edited by Brka; 03-04-2018 at 00:24. Reason: merged posts |
The Following 4 Users Say Thank You to GSM_FIX For This Useful Post: |
02-09-2018, 12:02 | #3 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Samsung
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | ZTE phones FRP bypass ZTE Maven 2 FRP bypass | ZTE Z831 Google account bypass | AT&T FRP bypass |
The Following 4 Users Say Thank You to Mobile-Lab For This Useful Post: |
02-09-2018, 12:04 | #4 (permalink) |
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | ZTE ZMAX PRO FRP bypass | ZTE Z981 Google account bypass | ZTE MetroPCS and T-Mobile FRP bypass |
The Following 3 Users Say Thank You to Mobile-Lab For This Useful Post: |
02-09-2018, 12:05 | #5 (permalink) |
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | ZTE Grand X3 FRP bypass | ZTE Z959 Google account bypass | ZTE Cricket FRP bypass |
02-12-2018, 12:03 | #6 (permalink) |
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | ZTE Avid Plus FRP bypass | ZTE Z828 Google account bypass | ZTE MetroPCS/TMobile FRP |
05-20-2018, 20:00 | #7 (permalink) |
Junior Member Join Date: Apr 2017 Location: USA CALIFORNIA
Member: 2704703 Status: Offline Thanks Meter: 0 | Help need remove frp zte z855 maven 4 metropcs I have one Zte Z855 Maven 4 Metropcs i try remove frp or google account but no possible is Qualcomm Chip MSM 8909 i try remove with xxxxxxx but fail The Method Try is: 1.- Put in FTM mode Open xxxxx 2.- FTM to edl mode with in menu zte 3.- go to menu Qualcomm and select internal Loader msm8909 or msm8909 2 gen. Last edited by Brka; 07-11-2018 at 23:35. Reason: Removed boxes |
08-16-2018, 22:25 | #8 (permalink) |
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | ZTE Maven FRP/Google account bypass | ZTE Z812 AT&T USA FRP/Google ID bypass |
11-04-2018, 19:41 | #9 (permalink) |
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | ZTE Z851M, Z855, Z981, Z982, Z983 and other ZTE Android 7.1.1 FRP / Google bypass without PC/Box - all just with wifi. This method will work on all ZTE phones/tablets with Android 7.1.1 |
01-15-2019, 12:52 | #12 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | ZTE Z981 Zmax Pro FRP unlock without PC. ZTE Z981 Zmax Pro FRP unlock without PC ANDROID VERSION 6.0. |
The Following User Says Thank You to asad_nomy7 For This Useful Post: |
03-21-2020, 23:33 | #13 (permalink) |
No Life Poster Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Offline Thanks Meter: 772 | How to Skip FRP in ZTE Axon 9 Pro – Bypass Google Verification Here we are coming with a tutorial, which will show you how to bypass Google verification in ZTE Axon 9 Pro. If you’re wondering how to skip FRP and activate your smartphone without Google credentials, then simply watch our video. Prepared tutorial will show you how to smoothly bypass this verification. Video manual: Normal manual with picture: How to bypass Google Account protection in ZTE Axon 9 Pro by HardReset.info Team manual |
06-04-2020, 19:33 | #14 (permalink) |
Freak Poster Join Date: Sep 2013 Location: Tepa,HnD
Member: 2033258 Status: Offline Thanks Meter: 61 | Zte z799vl Google bypass tool Please let me know if you need the software and make sure it’s the same model as described. Link to download the software https://drive.google.com/file/d/13zl...w?usp=drivesdk Once downloaded open it and put the phone in recovery mode and select apply updates from ADB thank choose 1 on the software hit enter and will see more changes at the bottom of the device Once done that it’s all it takes go to reboot system now and you will be able to bypass FRP on this device please share me a thanks. Cheers Sent from my iPhone using Tapatalk Last edited by darkside85; 06-04-2020 at 19:37. Reason: Topic |
08-17-2020, 11:47 | #15 (permalink) |
Member: 2771307 Status: Offline Thanks Meter: 772 | How to Bypass Google Verification in ZTE Nubia N1 Lite – Unlock FRP Are you wondering what you can do in a situation where you’ve forgotten the Google password for your ZTE Nubia N1 Lite? Here we are coming to present to you the best solution! Above video will show you all steps required to successfully bypass Google verification. Let’s follow all the shown steps and successfully remove Google block. Video manual: Normal manual with pictures: How to bypass Google Account protection in ZTE Nubia N1 lite with Android 6.x? |
