Huawei General Huawei phones and tablets help |
12-26-2013, 12:54 | #5 (permalink) |
No Life Poster Join Date: Sep 2008 Location: kutch, gujarat, india
Member: 852566 Status: Offline Thanks Meter: 464 | ROM Offical Huawei : G525-U00_EmotionUI_1.0_V100R001CHNC00B176 Description ROM HUAWEI G525 Glory – ROM Android 4.1.2 ROM Offical Huawei : G525-U00_EmotionUI_1.0_V100R001CHNC00B176 ROM install : Step one: Prepare an SD card, it is recommended to use *******, Kingstone, or Kingmax, size is recommended that more than 1G. Step Two: Formatting SD card (optional). The step three: copy a large package path UPDATA.APP to the SD card dload UPDATA.APP. Step four: Check the root directory of the SD card you dload UPDATA.APP. Step 5: SD card into the phone is switched on in the main screen, press the Menu key, the system updates -> SD card upgrade -> confirm -> upgrade, backup data, select the backup data; upgrade. Step Six: The upgrade process progress bar shows after the finish of the pending progress bar, the phone automatically restart. or Step one: Prepare an SD card, it is recommended to use *******, Kingstone, or Kingmax, size is recommended that more than 1G. Step Two: Formatting SD card (optional). The step three: copy a large package path UPDATA.APP to the SD card dload UPDATA.APP. Step four: Check the root directory of the SD card you dload UPDATA.APP. Step Four: cell phone turned off, insert the SD card, while pressing the volume up button + volume down key switch button, the phone automatically enters the upgrade mode, and then begin the upgrade in Figure Step Five: After the progress bar to go full fixed, the phone will automatically restart If you do not manually remove the battery. http://www.needrom.com/wp-content/up...CHNC00B176.zip |
The Following User Says Thank You to papu3090 For This Useful Post: |
12-26-2013, 13:15 | #6 (permalink) |
Junior Member Join Date: Nov 2007
Member: 638698 Status: Offline Thanks Meter: 2 | I have tried to download ROM HUAWEI G525 Glory – ROM Android 4.1.2 ROM Offical Huawei : G525-U00_EmotionUI_1.0_V100R001CHNC00B176 on the phone But I got a problem on firmware update step 2/2 (update failed) What is the solution to this problem? |
