Huawei General Huawei phones and tablets help |
04-17-2021, 09:17 | #18 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | use halabtech tool then for flash this https://androidfilehost.com/?fid=4349826312261714580 select 2 times rawprogram |
04-17-2021, 16:23 | #21 (permalink) |
Junior Member Join Date: Jan 2021 Location: Birmingham
Member: 2977819 Status: Offline Thanks Meter: 1 | Re: Yes, i did that. So here is the log: Opreation : write flash Drive found :Qualcomm HS-USB QDLoader 9008 (COM3) Model select :By Loader SerialNumber: 0xxxxxx MSM_HW_ID: 0xxxxxx OEM_PK_HASH: 0xxxxxxxxxxxx SBL SW Version: 0x00000000 Download loder : Successfully Flash sbl1.img....OK Flash rpm.img....OK Flash tz.img....OK Flash devcfg.img....OK Flash apdp.img....OK Flash msadp.img....OK Flash aboot.img....OK Flash keymaster.img....OK Flash modem.img....OK Flash erecovery_kernel.img....OK Flash erecovery_ramdis.img....OK Flash erecovery_vendor.img....OK Flash kernel.img....OK Flash ramdisk.img....OK Flash recovery_ramdisk.img....OK Flash recovery_vendor.img....OK Flash cache.img....OK Flash odm.img....OK Flash product.img....OK Flash vendor.img....OK Flash system.img....OK Flash preas.img....OK Flash preavs.img....OK Flash userdata.img....OK Write Rom is Done It appears to have written ok in EDL mode, but the phone still boots up in Fastboot? |
04-18-2021, 08:36 | #22 (permalink) |
Member: 2977819 Status: Offline Thanks Meter: 1 | So i reverted back to QFIL here is the log now. I see Divide by zero error. Any ideas? Programming the bootloader piece seems to work ok, its when it does the other images if fails. Process Index:0 Programmer Path:C:\Huawei\REPAIR\rawxml\prog_emmc_firehose.mb n Image Search Path:C:\Huawei\REPAIR\rawxml Please select the XML file Start Download Program Path:C:\Huawei\REPAIR\rawxml\prog_emmc_firehose.mb n COM Port number:3 Sahara Connecting ... Sahara Version:2 Start Sending Programmer Sending Programmer Finished Switch To FireHose Max Payload Size to Target:49152 Bytes Device Type:eMMC Platform:8x26 Disable Ack Raw Data Every N Packets Ack Raw Data:False Skip Write:False Always Validate:False Use Verbose:False COM Port number:3 Sending NOP FireHose NOP sent successfully Sending Configuration Device Type:eMMC Platform:8x26 Set TxBuffer 0x4000, RxBuffer 0x4000 Firehose configure packet sent successfully! Total Bytes To Program 0xA6434050 Download Image PROGRAM: Partition 0, Sector: 0, Length: 33 Sectors, Sector Size: 512 Bytes File: C:\Huawei\REPAIR\rawxml\gpt_back0.bin PROGRAM: Written Bytes 0x4200 (64) Program Size: 0.02 MB PROGRAM: Partition 0, Sector: 0, Length: 34 Sectors, Sector Size: 512 Bytes File: C:\Huawei\REPAIR\rawxml\gpt_main0.bin PROGRAM: Written Bytes 0x4400 (64) Program Size: 0.02 MB PROGRAM: Partition 0, Sector: 9175040, Length: 0 Sectors, Sector Size: 512 Bytes File: C:\Huawei\REPAIR\rawxml\USERDATA.img Download Fail:System.DivideByZeroException: Attempted to divide by zero. at QC.QMSLPhone.Phone.QLIB_QPHONEMS_UploadEmmcImages_ FireHose(UInt32 handle, SWDL_eMMC_UserPartitionList& pPartitionList, Single& imageSizeInMB, Single& throughput) at QC.QMSLPhone.Phone.QPHONEMS_UploadEmmcImages_FireH ose(String rawprogramfile1, String patchfile1, String rawprogramfile2, String patchfile2, String rawprogramfile3, String patchfile3, String rawprogramfile4, String patchfile4, String rawprogramfile5, String patchfile5, String rawprogramfile6, String patchfile6, String rawprogramfile7, String patchfile7, String rawprogramfile8, String patchfile8, String rawprogramfile9, String patchfile9, String rawprogramfile10, String patchfile10, Single& imageSizeInMB, Single& throughput, Int32 NumberOfFiles) at QC.SwDownloadDLL.SwDownload.FireHoseDownloadImage( Boolean bResetPhone, List`1 rawprogramFilesList, List`1 patchFilesList, Single& fImageSizeInMB, Single& fThroughput) Download Fail:FireHose Fail FireHose Fail Finish Download Start Download Program Path:C:\Huawei\REPAIR\rawxml\prog_emmc_firehose.mb n COM Port number:3 Sahara Connecting ... Sahara Version:0 Start Sending Programmer Download Fail:System.Exception: Unable to download Flash Programmer using Sahara Protocol at QC.QMSLPhone.Phone.QPHONEMS_SaharaArmPrgDownload(S tring sFileName) at QC.SwDownloadDLL.SwDownload.QPHONEMSSaharaDownload ArmPrg(UInt64& version, String armPrgPath) Download Fail:Sahara FailSahara Fail Finish Download |
04-18-2021, 20:51 | #24 (permalink) |
Member: 2977819 Status: Offline Thanks Meter: 1 | Re: Thanks kickass, but still no success and only Qfil version 1.0 seems to work on my PC. The newest version throws errors. I think if I'm going to fix this, I will need to have a Qfil backup off a working DUB-LX1. If anyone could share an image with me, I'd be delighted! Spent too many hours on this. |
04-19-2021, 17:52 | #27 (permalink) |
Member: 2977819 Status: Offline Thanks Meter: 1 | Phone is sorted!! My special thanks to Kikas112, who was a great fountain of knowledge to help sort a fix for me. Top man! |
The Following User Says Thank You to johnbeatle For This Useful Post: |
