Hard reset micromax a72 in easy step You need, a72 with pattern lock, computer, multitool, data cable and proper driver. Step: 1) switch on mobile 2) connect with pc. Wait for driver installing. 3) after instal driver, open multitool 1.2b version. And press 1 and check for the device. If multitool get the device the follow next step. 4) press 0 for goto command prompt. 5) in command just type adb reboot recovery. After press enter mobile restarted with recovery menu.If menu not come just press home button. Its done. Now u can wipe data, format etc. Thanks |
it only works if by luck usb debugging is enabled . also if usb debugging is enabled then you can easily remove pattern lock or google a/c lock without data loss. |
Yes this method perfectly work. If adb is on just go to command prompt Type " Abd Reboot recovery " Phone goes in recovery menu and wipe it. kalpesh Varia |
br. |
Bro micromax a72 vol- vol+ key damage Problame pettern lock How to solve problame |
try this and post result ...... |
