Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 10-01-2013, 19:19   #1 (permalink)
SAHIL MIDHA's Avatar
Member: 509348
Thanks Meter: 116
canvas hd a116 touch problem
i replaced new touch in a116 canvas hd , but it will sometimes auto work and sometimes stop working , i fixed a original touch ,
i faced this problem in diffrent handsets of same model , and all touch i replaced r original ,
is there any software or method for calibrating or any other touch solving method for this problem
i am sure tht new touches r not faulty , all r original
Old 08-22-2014, 06:39   #2 (permalink)
Member: 1305225
Thanks Meter: 30
micro max a116 pcb layout needed................can any one help me?
Old 08-26-2014, 07:00   #3 (permalink)
Member: 1030568
Thanks Meter: 67
i need also any solution
Old 03-09-2015, 12:15   #4 (permalink)
Member: 459557
this problem is not a complaint of touch pad..
the complaint shown because touch fitting is not perfect setting
use double side sticker 1 or 2 layer in the touch pade's BOARDER side
Old 03-27-2015, 12:56   #5 (permalink)
Member: 917110
Sonork: 0000
HAII THIS IS NEW VERSION TOUCH PANEL PLS UPDATE A116 i FLASH FILE
Old 03-28-2015, 16:08   #6 (permalink)
Member: 2370064
Sonork: 100.1663672
Some time display gets contact with the touch pad. fix the display properly to the panel and then stick the touch pad properly to the frame .YOUR PROBLEM MUST BE SOLVED I HOPE SO......
Page generated in 0.12645 seconds with 8 queries
