Micromax General Micromax phones discussion, firmwares, solution, root, help |
07-02-2014, 07:11 | #1 (permalink) |
Insane Poster Join Date: Apr 2014 Location: nagaon(Assam) India Age: 31
Member: 2177797 Status: Offline Sonork: 100.1655224 Thanks Meter: 15 | micromax doodle 3 hard reset procedure press power button + volume up button Next from the menu choose option "wipe data/factory reset" using Volume buttons to scroll options, and volume up to conferm operation. Then you will see next menu, and from this menu select option "Yes -- delete all user data". After this process, accept option "reboot system now". Success! |
The Following User Says Thank You to sukhdeb For This Useful Post: |
08-10-2015, 07:27 | #3 (permalink) |
Insane Poster Join Date: Jul 2012 Location: vizag
Member: 1784493 Status: Offline Thanks Meter: 20 | micromax A102 doodles 3 patternlock remove by miracle micromax A102 doodles 3 patternlock remove by miracle first install drivers press vol down and connect with usb to pc automatically install drivers wait untill install drivers........... mtk--8th boot--reset code ---run insert batt--press vol down and connect usb 10000% done |
