micromax a311 flashing problem I[SIZE="3"]need help about flashing micromaxa311 flashing I have also a flash files or tool. But tell me how to I connect that device in flashing I instaal all mtk drivers now |
First thanks friend to reply my post I have also a flash file or tool but problem is this my device connect in comport mtk port but the ygdp tool can't detect this my device in cell How to I connect my device in ygdp tool please solve my this problem |
Hello . Isn't there s scatter file in your firmware ?if yes. Use SP_Flash_Tool_v5.1452.00.000 . Select Scatter then Select firmware Upgrage , reconnect battery then Connect Phone.. Wait few mins & done! (make sure u flash proper firmware). Or CPB file? |
no sir,i have no scatter file |
What was the phone status? why you decided to flash ? |
we are facing same problem, please help me any one........................................ |
this device unfortunately applications sttoped problem.. |
no solution this problem? |
this is driver problem install mtk 6592 driver |
Hello... the actual problem here as faced above is that the files for A311 is flashed with YGDP tool which supports qualcom cpu... But today as i am trying to flash a similar A311, it detects MTK6592 cpu not qualcomm... I tried in 3 different laptops, all showing mtk preloader ... So, driver is not an issue here... The issue is wrong software... This Micromax A311 Sticker says H/w Ver: P1 S/w Ver. 4.4-012 Even Inferno MTK is detecting as MTK6592 cpu... but fails to read full info... So here we need MTK flash File and not qualcom file as available... |
If there is any other solution then plz do post |
http://mtk-p.micromaxinfo.com/produc....8297W_I02.rar and if ur mobile stuck on factory mode try these comands in fastboot mode adb shell "fctest system reboot" |
for ygdp tool to detect phone need only "preloader usb vcom driver" other will not work. no need to insert battery connect direct usb cable without pressing anything. |
where can we find preloader usb vcom driver |
