Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 03-18-2014, 06:38   #1 (permalink)
Member: 2141811
Thanks Meter: 38
Question Micromax x325 Problem
I hv a Micromax X325 Mobile, which is now shutdown and didn't switch on and before switch off it has 100% charge. Then I remove the battery and then I put it back, it was turned on. Later it again switched off.
What should I do? I think it need Flash.
Plz Guyz Help me....
Thanx in advance
Old 03-18-2014, 07:11   #2 (permalink)
Member: 2082450
Thanks Meter: 1,454
It don't need flash.
Check the voltage at the output of power ic. If it is less than 2v, then u have to check the board short.
Possible solutions
1 first of all clean the mb completely and then try.
2 if not solve try the direct vbat jumpering from the output to input.
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 03-18-2014, 07:19   #3 (permalink)
Member: 2141811
Thanks Meter: 38
Nothing problem in the voltage, it automatically switch off.
I forget to mention 1 thing that after switch the battery level is low and says Battery Low.
When I it turn on, it generate heat????
What's wrong with this????
Old 03-18-2014, 07:39   #4 (permalink)
Member: 2141811
Thanks Meter: 38
And one more thing Now another problem - Now Mobile is Network Searching Mode....
No network...
Plz Reply
Old 03-18-2014, 09:14   #5 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
No network...
Plz Reply
working sat read file after nv Write
Old 03-18-2014, 12:17   #6 (permalink)
Member: 2141811
Thanks Meter: 38
Still the problem is same
Old 03-18-2014, 17:01   #7 (permalink)
Member: 2082450
Thanks Meter: 1,454
Set read file and write nv.
Old 03-19-2014, 07:57   #8 (permalink)
Member: 2141811
Thanks Meter: 38
How?
Can u explain????
Old 03-19-2014, 14:30   #9 (permalink)
Member: 2082450
Thanks Meter: 1,454
U have to use dragon or volcano box for this purpose.
First of all buy one of them, then tell, i will tell u the process.
Old 03-19-2014, 15:34   #10 (permalink)
Member: 2141811
Thanks Meter: 38
How funny
No thanks
Old 03-20-2014, 12:57   #11 (permalink)
Member: 2082450
Thanks Meter: 1,454
There is no fun here.
If u have really any issue then post.
Old 03-21-2014, 10:45   #12 (permalink)
Member: 2141811
Thanks Meter: 38
Tell me chandanps18 Why I m going to buy Dragon or Volcano box????
Old 03-21-2014, 10:45   #13 (permalink)
Member: 2141811
Thanks Meter: 38
Old 03-21-2014, 14:49   #14 (permalink)
Member: 2082450
Thanks Meter: 1,454
If u want to solve ur problems, then the above said box will help you.
Page generated in 0.21190 seconds with 8 queries
