Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 06-22-2013, 15:51   #16 (permalink)
Member: 1150176
Sonork: stelecom.2009
Thanks Meter: 33
no format volocon pls full post video help sir....................
Old 06-23-2013, 11:39   #17 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,266
what probem u are facing, post here some details about ur phone.
Br,
azam
Old 06-27-2013, 11:17   #18 (permalink)
Member: 170544
a72 micromax
thnx sir
after flash my handset dead
u solve my porblem
thnx
Old 06-27-2013, 12:01   #19 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
Originally Posted by vaghubha_sodha View Post
i am boot keey soldeing here to grd
but phone conect here few secnd after this eroor show here
here my prob pic
try this.
go to flash tool option>da download all>speed>forsed high speed.
and click da dl all with chack sum
try with battery and without battery option click in flash tool
solve your problam
Old 06-28-2013, 18:16   #20 (permalink)
Member: 765926
Thanks Meter: 57
micromax a72 hard reset done without flash.
Recently I came across an a72 canvas with pattern lock. As I read this thread, it seemed impossible to hard reset it with key combinations. I tried it with volcano but it didn't connect. Then I put the volcano pinout cable in the phone while the phone was switched off. Started the volcano pinout search by clicking run. Presses the volume down and power on button. I kept the power on button pressed and suddenly the android logo showed up on the phone. I disconnected the volcano. And used the bottom left key to get into the menu. Then wiped the date. And it was done.
So please do not say that Iy cannot be done without flashing. There is no android based phone that cannot be hand formatted. I think the volcano cable had nothing to do with it. It was just the rigjt key conbination. So don't misguide others
The Following 2 Users Say Thank You to morpheus.xi For This Useful Post:
Old 06-28-2013, 21:01   #21 (permalink)
Member: 505794
Thanks Meter: 2,266
Yes you are rit androids phone can be hard reset with keys combination, nobody said can't be format with keys combination. We just said till date no solution.
its good news u format ur A72 with keys so plz post here full details that how to format with hardware keys.
Br,
azam
The Following User Says Thank You to ..::Nokian CareŽ::.. For This Useful Post:
Old 06-29-2013, 06:47   #22 (permalink)
Member: 765926
Thanks Meter: 57
Br,
azam
Yes. switch off the mobile, press volume down, and insert usb cable, press the power switch and keep it pressed until the android logo shows up. sometimes it does'nt show so u have to try 3 or four times. then use the bottom left key to enter the menu;. i will post the screen shots
Old 06-29-2013, 07:41   #23 (permalink)
Member: 765926
Thanks Meter: 57
here are the screen shots
Check the screen shots
View image: IMG 20130629 00048
http://s21.postimg.org/87wsczc8n/IMG_20130629_00049.jpg
The Following User Says Thank You to morpheus.xi For This Useful Post:
Old 07-01-2013, 12:07   #24 (permalink)
Member: 171342
Thanks Meter: 36
worked & tested ok 1000000000000%
The Following User Says Thank You to nanu For This Useful Post:
Old 08-10-2013, 06:20   #25 (permalink)
Member: 1993662
how to micromax a72 hard reset? give me solution.
Old 08-10-2013, 09:23   #26 (permalink)
Sanjeev_Chauhan's Avatar
Member: 1663011
Sonork: 100.1609944 QQ.1504180136
Thanks Meter: 1,594
Micromax A72 Hang On Logo Problem Solve..
http://forum.gsmhosting.com/vbb/f811...solve-1684238/
Enjoy.....
Br-Sanjeev Chauhan
India
Old 08-11-2013, 11:47   #27 (permalink)
Member: 923949
MICROMAX A-72 just format with volcano box........ HOW
Old 08-14-2013, 10:47   #28 (permalink)
Member: 1851179
my micromax a75 battery backup is very low plz solution
Old 08-22-2013, 15:19   #29 (permalink)
Member: 1900073
micromax pattern lock
Old 08-24-2013, 06:39   #30 (permalink)
shohidsd1's Avatar
Member: 1706809
Thanks Meter: 63
100% done................ see
Page generated in 0.23661 seconds with 8 queries
