GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Micromax (https://forum.gsmhosting.com/vbb/f811/)
-   -   Post Here All Successfull Flashed Micromax Phones with Factory Flasher & File (https://forum.gsmhosting.com/vbb/f811/post-here-all-successfull-flashed-micromax-phones-factory-flasher-file-1639613/)
..::Nokian Care«::.. 04-06-2013 13:42
# Share here your all successfull flash stories of Micromax Phones
# If possible make flashing manual for users help
Note:
Use this thread for share success stories & manual only.
Don't make any file, flasher & manual request here.
Most of them can be, anyway, downloaded Here
Thnx post will be deleted without any warning.
azam
..::Nokian Care«::.. 04-06-2013 14:21
Micromax X456 Successfully flashed with manual
Micromax X456 flashing manual step by step
Download Flasher & Firmware From Here
Open FlashTool_v5.1220.00
Click on Scatter/Config File & select cfg File
Click on option & tick on USB Download/Readback now Scroll down to Backup and Restore & tick on Backup ->Download/Format -> Restore
Now finaly click on Download & plug USB cable to your powerd off phone
Wait for finished & Enjoy......(if failed try again)
http://img809.imageshack.us/img809/9201/11111oj.png
Flashing Hints:No boot key needed for flash this phone just connect power phone.
azam
Prem_India 04-06-2013 15:33
Micromax X231 Flash Done (FlashTool_v5.1140.00)
http://i1206.photobucket.com/albums/...psd3df976a.png
Download Flash FIle And Flasher Here
Process Same
See Post 2
B.R.,
Prem_India
Prem_India 06-18-2013 09:36
Micromax Canvas Viva A72 Flashed Done By OG Flash Tool
Google User Name/Password Remove Successfully
After Click On Download
Insert USB Cable
http://www.google.co.in/url?sa=i&sou...71629989080197
http://www.youtube.com/watch?v=JBwqzjUAUxs
Download Video
A72 Flash File And Flasher Download Here
B.R.,
Prem_India
Prem_India 07-05-2013 07:12
Micromax A25 Flash With OG Flash Tool AND Flasher
Micromax A25 Flash With OG Flash Tool And Flasher
http://images.fonearena.com/blog/wp-...one-Smarty.jpg
OpenSP_Flash_Tool_v3.1207.03_forGoinee Folder
Double Click On Flash Tool.exe
http://imageshack.us/a/img534/9895/y9p.png
Click On Scatter-Loading
GO TO A25_0201_T0370 Folder
Select MT6575_Android_scatter File
Than Click On Download
http://imageshack.us/a/img199/1669/xsi.png
Insert Modified Cable OR Boot With Any China Box
Flash With Start
http://imageshack.us/a/img9/9031/8qv.png
http://imageshack.us/a/img69/1562/gvu0.png
http://imageshack.us/a/img824/2088/9eeh.png
Micromax A25 Flashing Video
http://www.youtube.com/watch?v=s9MSi-48Ohs
Download Video
Download Flash File And Flasher Here
B.R.,
Prem_India
mobile house dinajpur 09-01-2013 13:36
Micromax a-27 bolt flas done by og.
The software version “ZE25PAA_060A_V8_0_7” is confirmed.
Release note:
1. change power on-off animation;
2. add M! Zone+ launcher apk ;
3. add launcher for 2 games (tigerwoods & FIFA10)
http://my.jetscreenshot.com/10753/m_...-m8dt-22kb.jpg
BOOT KEY VOL DOWN,
FLAS FILE
http://www.moulnisky.com/index.php?d...60A_V8_0_7.rar
OK FLASHER HERE
http://www.moulnisky.com/index.php?d..._R2.9.7006.rar
http://my.jetscreenshot.com/10753/m_...-dfhn-52kb.jpg
cellcare prasad 11-20-2013 19:11
MICROMAX P362 TAB TOUCH NOTWORKING AFTER FLASH SUCCESSFULLY RECTIFIED WITH LATEST TOUCH FIX VERSION
http://img801.imageshack.us/img801/5503/vrs0.png
BRO
PRASAD
Prem_India 01-03-2014 07:45
MIcromax A52 Dead Recover & Repiar IMEI Done By OG Tool And Flasher
.::TEJARAM::. 02-28-2014 09:04
Micromax A35 [Pattern/Google Lock Removed] Done
http://s24.postimg.org/h4nr44oc5/2014_02_07_164548.png
.::TEJARAM::. 03-03-2014 14:51
Micromax A27 flash success
.::TEJARAM::. 03-10-2014 10:15
a65 successful flash
bishnuprasad884 03-21-2014 08:28
Flashing Firmware Image Files Using The Rockchip Batch Tool
This is a quick guide to Flash single firmware image files onto your tablet. Manufacturers mainly provide single image files to upgrade tablets, as do some Rom Cookers for their custom firmwares. If you want to install a custom firmware or want to return your tablet back to a manufacturers stock rom, for warranty purposes etc this is sometimes the only way to do it. It is quite straightforward to do so here we go!
Firstly this is presuming that you have already installed the Rockchip drivers for your tablet if not follow my guide here: http://www.freaktab.com/showthread.pů-for-flashing!
STEP 1
Make sure your tablet is charged. Download the Rockchip batch tool
Rockchip Batch Tool Download
STEP2
Unzip the file and start the RKBatchTool program, and use the firmware path selector to find your firmware image.
http://www.freaktab.com/attachment.p...9&d=1334701624
Now put your tablet into recovery mode or flash mode as it is sometimes called and connect it to your PC. As you will see you will see that your device is connected, indicated by the green box. If you are upgrading from say a manufacturers Rom to a new version that hit the upgrade button, if you are installing a custom firmware that usually it is the restore button.
http://www.freaktab.com/attachment.p...0&d=1334702633
Step 3
Once you have done this the software will send the firmware to your tablet and the flashing process will begin, you will see firmware loading on the RockchipBatchTool screen, just leave it to do its work and be patient and be careful not to knock or touch anything while it is flashing. Once the process has completed your tablet will disconnect from the program and the green box will not be highlighted. Now the tablet will begin to flash and reboot with your new firmware on it!
.::TEJARAM::. 04-04-2014 10:04
.::TEJARAM::. 04-09-2014 13:01
Micromax A72 [Pattern/Google Lock Removed] Done
.::TEJARAM::. 04-12-2014 11:53
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.15094 seconds with 6 queries
