Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod - FAQ, Guide, How To, Tutorials , News
iPhone, iPad, iPod - FAQ, Guide, How To, Tutorials , News iPhone, iPad, iPod Jail break, Activation and Unlocking Step by Step How-To: Help, Guides , Tutorials and News
Old 04-14-2020, 14:51   #1 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,501
Lightbulb FREE CELLULAR FIX for Passcode Locked & Disabled iPhone/iPad (Apple Tech)
If you have an iphone or ipad passcode locked / disabled, it is now possible to bypass icloud and activate your device. Your device needs to be already FactoryActivated to use this method. If you just erase or restore, bypass iCloud and then add a passcode that’s not the same thing. This will not work. You need a checkra1n compatible device with a passcode or FactoryActivated device.
how you can activate CALLS and CELLULAR DATA on your passcode locked/disabled iDevices using Apple Tech 752 Sliver 4.2, powerful iCloud Bypass tool for macOS High Sierra.
http://www.youtube.com/watch?v=nT_ZMdtpGso
NOTE: Before you do anything we are not responsible for what you do with your device. This is still in beta, we still need to do more tests and make compatible with all devices, if this method doesn’t work you should wait for new update or try again step by step.
jailbreak with checkra1n
use the software to read your activation data
restore your device to the latest iOS (ipsw)
jailbreak again and bypass icloud using software
relay device info and activate your device
done
Follow the video tutorial, If it does not work on the first try, that’s normal. Just keep trying again and always click relay device info before activating the device. Eventually, you’ll get lucky, some devices took me 10 or more tries. For now, this method is only compatible with passcode locked/disabled devices. However, developers will always looking for ways to add features to Sliver and will continue to update and improve it.
Download
Silver 4.2 ( macOS High Sierra )
Download Silver 4.2 ( windows version )
FREE CELLULAR FIX for Passcode Locked & Disabled windows tools
If this software doesn’t work with your macOS, you can try using the manual files with terminal, since this tool only supports Hight Sierra Mac OS you may want to try terminal files using command lines to activate your device. This method was created and developed by @hpegar from twitter.
How to Fix CELLULAR for Passcode Locked & Disabled iPhone/iPad!
MANUAL METHOD
1. DEVICE MUST BE PASSCODE OR DISABLED
Download this files ( put the files into the desktop )
2.Connect device and jailbreak with checkra1n
EXECUTE “IPROXY 2222 44” in new window or tcprelay
Exec 1.sh ( new terminal window)
RESTORE IPHONE Latest VERSION
JAILBREAK AGAIN
RUN THIS COMMAND – “scp -r -P 2222 /Users/YOURUSERNAME/Desktop/ssh\ files/3/Library/ [email protected]:/private/var/wireless/“
EXEC 2.h and copy the GUID Example (86FA201C-9D8C-4DAF-BF6D-2AF8669F5ED0)
REPLACE /00000-000/ THIS WITH RANDOM GUID PROVIDED ON 2.sh
EXECUTE THIS “scp -r -P 2222 /Users/YOURUSERNAME/Desktop/ssh\ files/4/Library [email protected]:/private/var/containers/Data/System/0000000-0000000-000000/“
done
All thanks to @hpegar
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
The Following 7 Users Say Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 04-19-2020, 15:51   #2 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,621
done
Download
MANUAL METHOD
JAILBREAK AGAIN
done
thx for this information, and good explanation
but my question about passcode
there is any way to just disable passcode and keep all information inside.
i just need to find the email or phone number for the owner of this iPhone i have it on hand.
The Following User Says Thank You to hitibiti For This Useful Post:
Old 04-20-2020, 09:34   #3 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,501
Passcode Disabled Data will be Erased!
No Solution
__________________
__________________
Best Regards,
Shamim
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 04-21-2020, 19:46   #4 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,160
No Solution
Hm.... There is something interested for passcode\network problem
https://myicloud.info/how-disable-pa...-with-carrier/
Old 04-25-2020, 17:11   #5 (permalink)
cooloxf's Avatar
Member: 120893
Thanks Meter: 69
thank s for the good solution
Old 04-25-2020, 17:14   #6 (permalink)
mitcom's Avatar
Member: 887023
Thanks Meter: 16
tested and working iphone 6s thanks appletech
Old 04-29-2020, 04:41   #7 (permalink)
Stunman112's Avatar
Member: 2567774
Thanks Meter: 254
iF bypassed will Reset/Relock?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Old 04-29-2020, 06:14   #8 (permalink)
.:==di@bila==:.'s Avatar
Member: 254137
Sonork: 1592525
Thanks Meter: 275
No, it's untethered so no more lock.
br
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.18456 seconds with 7 queries
