[] iCloud Bypass & iTunes Sync Patch [] for Windows [] iCloud Bypass & iTunes Sync Patch [] https://uc84b4edcc267afcb73afd3fac77...ue&size_mode=5 https://drive.google.com/file/d/1hMr...ew?usp=sharing https://www.dropbox.com/s/klpug1btr7...5B%5D.rar?dl=0 br RNC_EBM |
how to use it .any instructions |
check here guys https://www.4shared.com/s/fb0kFMia6ea instructions: 1st: jailbreak your device using checkra1n 2nd: download files on the given link above and extract it 3rd: install python in pc..installer is included inside choose correct bit version of your pc 4th: if your pc is in 32bit you need to copy putty and pscp.exe from the putty32 folder to the library folder 5th:select and click icloud bypass button depends on your ios version you will have error message from putty just type Y and press enter 6th:after bypass was done do activation setup process on your iphone and you will see its activated in itunes this is not my work only sharing it to help people press thanks if you like my post |
is there any bypass method to be able to use sim card call & data ???? |
its shows network error ??? |
iphone 5,5c are supported or nt? |
br RNC_EBM |
but only paid service by flexihub |
cost like 70 to 80$ depends on models |
