03-30-2013, 20:30 | #61 (permalink) |
Junior Member Join Date: Mar 2013 Location: Poland
Member: 1909006 Status: Offline Thanks Meter: 1 | Anyway if someone wants help with password or pinlock in Poland or Europe, simply email or PM me. |
04-03-2013, 20:50 | #62 (permalink) | |
Member: 1909006 Status: Offline Thanks Meter: 1 | Quote:
Just tested on A1286 (mid 2012) , have different EFI data but pass remove still work perfect. | |
04-12-2013, 00:11 | #63 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1887169 Status: Offline Thanks Meter: 0 | hi guys i have macbook pro late 2011 any solution free for this model? i tried many things no solution remove ram does not work this is mys hash C0721020237DTN3BQ117AE03C76C3250C thanks a lot !!! |
04-12-2013, 00:36 | #64 (permalink) | |
Unfortunate there are not any remote solution, guess why ? because your system is locked, so not system activity, so not working with net, so not remote solution. Or try at Apple Store, maybe they can help you. | |
The Following User Says Thank You to remzibi For This Useful Post: |
05-17-2013, 15:56 | #66 (permalink) |
Junior Member Join Date: May 2013
Member: 1934040 Status: Offline Thanks Meter: 0 | How to remove efi password macbook 2011 HI I KNOW HOW TO REPROGRAM EFI CHIP ON MAC BUT MY PROBLEM IS WHERE CAN I GET firmware FOR REPROGRAM EFI CHIP I USE A EXTERNAL bios programmer SOMEBODY KNOW WHERE DO I DOWNLOAD FIRMWARE FOR EFI CHIP THANKS YOU |
05-27-2013, 17:01 | #69 (permalink) |
No Life Poster Join Date: Nov 2006 Age: 41
Member: 389660 Status: Offline Thanks Meter: 60 | Problem: Your Mac got locked via iCloud and on boot displays "Enter your system lock PIN code to unlock this Mac." It also sets an unknown password on the firmware so you can't boot from a disc. And you don't know the PIN code for a variety of reasons (not my business). Thumb resize. Solution: Mount the locked drive on another machine, find the PIN, re-install the locked drive into the original Mac, enter the PIN, resume your business. Tutorial: *I'm going to post the steps I did in my case and suggest steps you might take if your case varies. Things Needed: 1. Alternate machine with space to mount an additional drive. (works on Mac or PC*) *If you're using a PC, you'll need to download and install Mac Drive to be able to read the contents from a Windows environment. 2. You might need a SATA to USB adapter if you have a laptop without room for an additional drive. 3. Screw driver to disassemble the Mac. Step 1: Remove the locked hard drive from your Mac. You can find detailed guides for your specific machine at Mac Repair - iFixit Step 2: Install the drive into your alternate machine. But make sure you do *not* boot from it. Boot from your regular drive. If you do not have an alternate machine, feel free to ask a tech buddy of yours to lend you their machine. Step 3: Once booted into the alternate system, locate your locked drive. In my case it was drive D: on Windows. Now browse to \Users\username\Library\Application Support\iCloud Thumb resize. Step 4: In the folder "iCloud" find a file named with a bunch of numbers: ##########.lock In my case it was: 1138515150.lock Thumb resize. Step 5: I'd suggest that you take a picture of this file name for accurate reference. But you can also just write it down. Step 6: Once you got the number, power down the machine and remove the locked drive. Step 7: Install the locked drive back into the original locked Mac. Follow your iFixit guide from Step 1 in reverse to put the drive back. *It is important that you put it back in the machine where it was originally locked* so that the motherboard firmware will be unlocked in the next step. Step 8: Boot up the locked Mac and referencing the number you recorded, you can start trying 4 numbers at a time for the PIN. Try the first 4, then the second 4, and so on.. For example: 1138, 1385, 3851, 8515, 5151, 1515, 5150. In my case the PIN was the second to last 4 digits: 1515 If you typed in more than 10 combinations, then it says that you are locked out for a minute. Just restart the machine and continue entering the combinations from where you left off. Once you enter the right PIN, the Mac will instantly reboot proceeding to where you were at when the lockout occurred. It will also remove the firmware password. Enjoy your unlocked Mac!! And please let us know if this method worked for you. Thanks Many people are having trouble unlocking with the above method, so we are trying to figure this out collectively. Please help us help you; see this post by vladichimescu. |
05-29-2013, 04:15 | #70 (permalink) |
Major Poster Join Date: Jun 2004 Location: brazil Age: 47
Member: 68265 Status: Offline Thanks Meter: 2 | hi , im from brazil i have a macbook air 2011 need to reset efi password and 4 digit password , , its possible you help me ???? [email protected] |
05-29-2013, 09:44 | #71 (permalink) | |
Junior Member Join Date: Aug 2007 Location: Moranbah, Australia
Member: 568166 Status: Offline Thanks Meter: 3 | Quote:
05-31-2013, 14:03 | #72 (permalink) |
Junior Member Join Date: Dec 2008 Location: Prishtina
Member: 925517 Status: Offline Sonork: Keni Thanks Meter: 3 | Good solution for this is using t e n s y 3.0 board. This board can be easy programed and you can use it as keyboard to give codes for you. More reading about this issue can be found here: How to: Unlock System Lock PIN Code - Page 13 - MacRumors Forums |
06-06-2013, 16:13 | #73 (permalink) | |
Update Confirmed unlock on A1278 MacBook Pro (13-inch, Late 2011) A1405 MacBook Air (13-inch, Mid 2012) A1369 MacBook Air (13-inch, Late 2010) A1419 iMac (27-inch, Late 2012) | |
12-10-2013, 05:12 | #74 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2057540 Status: Offline Thanks Meter: 0 | The macbook chip is a high speed eprom . Spi package need a programmer capable of reading writing and erasing. I just need good bins I have everything else . Its really easy guys. The other method with those other self ccontained programmers don't write a new bin but it serosnout the areas o n bios chip thatbthe lock is on. |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
