MacBook Schematic+BRD Collection hello i want to share with all members my collection :D Macbook Air 13″ (Late*2008) 820-2375-A 820-2375-B 820-2375 Download Macbook Air 13″ (Mid 2009) 820-2375-A 820-2375-B 820-2375 Download Macbook Air 13″ (Late 2010) 820-2838-A 820-2838-B 820-2838 Download Macbook Air 13″ (Mid 2011) 820-3023-A (4GB) 820-3023-B 820-3023 Download Macbook Air 13″ (Mid 2012) 820-3209-A (4GB) 820-3209-B*(8GB) 820-3209 Download Macbook Air 13″ (2013-2014) 820-3437-A (4GB) 820-3437-B (8GB) 820-3437 Download Macbook Air 11″ (Late 2010) 820-2796-A 820-2796-B 820-2796 Download Macbook Air 11″ (Mid 2011) 820-3024-A (2GB) 820-3024-B (4GB) 820-3024 Download Macbook Air 11″ (Mid 2012) 820-3208-A(4GB) 820-3208-B (8GB) 820-3208 Download Macbook Air 11″ (2013-2014) 820-3435-A (4GB) 820-3435-B (8GB) 820-3435 Download Macbook Pro 13″ (Mid 2009) 820-2530 820-2530-A 820-2530-B Download Macbook Pro 13″ (Mid 2012) 820-3115 820-3115-A 820-3115-B Download Macbook Pro Retina 13″ (Late 2012 Early 2013) 820-3462 820-3462-A 820-3462-B Download Macbook Pro Retina 13″ (Late*2013) 820-3536 820-3536-A 820-3536-B Download Macbook Pro 15″ (Mid 2009) 820-2523 820-2523-A 820-2523-B Download Macbook Pro Retina 15″*(Mid 2012) 820-3332 820-3332-A 820-3332-B Download Macbook Pro Retina 15″*(Early 2013) 820-3332 820-3332-A 820-3332-B Download openboardview.exe for Windows Download OpenBoardView-R7.3-Darwin.dmg for Macosx Download don't forget to thank me!!!!!!!!!!!!! |
is this a joke? if not you need to fix it! couldn't download any file. All i get is malware and browser hijacks. |
virus what wrong with you???? |
Macbook Pro Mid 2015 Hi does any body has a board view and schematic for a Mac book Pro Mid 2015. Board Number : 820-00138A Thanks |
Macbook Pro Mid 2015 I have a MacBook Pro Mid 2015 A1398 , I have the audio jack stuck in optical mode , I replaced the jack and now the stuck in optical mode is gone. The MacBook used to chime when powered on , but now does not. But the sound still does not work from internal speaker or jack , if I connected Bluetooth headphones the sound works , if I plug a USB-Audio adapter the sound works. I have checked the following : Ok was checking voltages at C6600/C6601 = 3.3v and pin 10 audio jack same , then checked back to R6322 missing board revision / R6324/R6325/C6212 all 3.3v checked PP3V3_SO_AUDIO_ANALOG =3.3v checked C6302 =1.5v fed from U6200 checked pins 1-6 as follows 1=1.5v 2=0v 3=1.2v 4=3.3v 5=0v 6=4.9v pins 1 and 3 should be 4.5v , checked capacitor C6203 connected to pin 3 and both sides shorted so removed , need to check R6200 and C6200 I think it should be 4.5v and not 3.3v I think going to pin 4 u6200 Checked all components now L6201/C6213/C6214/C6212 = 3.3v C6216/C6217/C6218/L6201 =0v should be 3.3v traced back to audio chip (u6201) and no vref should be 4.5v but output =0v does it mean the audio chip u6201 is faulty and need replacing or u6200 that powers the chip if I feed 4.5v direct to c6213 to put 4.5v there will it damage anything ??? I have found that the power chip U6200 is not output the correct 4.5v , traced back to Pin 10 of the sound chip and no voltage out. Is it the Cirrus Logic power amp IC or some thing else, I can only find 1 fuse on the board are there any more. Also no the display has failed when I was checking voltages back to the LCD connector 5v feed. It is a A1398 , 820-00138-A logic board MBP Mid 2015. Any help would be great :( |
good thanks but some models not added |
is there special browser to use for download? uploadocean isnt displaying a download link using explorer or chrome :( |
Macbook Pro Retina 13″ (Late*2013) no power, magsafe greenlight when battery connected little water damage in keyboard backlight (cleaned) need help please ! |
Anyone can help out with .brd for 820-00165-02 (MacBook Air Early 2015). The site https://www.apple-schematic.se/board-ids/ doesn't offer one. I have the issue that it doesn't turn on. When plugging in the charger it is green for about 3seconds and then turns orange. No fan spinning when plugging in the charger. Thanks in advance |
did you try to power on with on/off testpoint the keyboard can be defect after waterdamage and the power on button doesn t respond |
Please somenone have schematic A1347 MAC MINI tanks |
