Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iMac, Macbook Pro, Macbook Air
Old 10-23-2013, 18:24   #16 (permalink)
Member: 8379
Thanks Meter: 35
Any Free solution I can unlock the mac book pro 13 A1278 (2011 model)
Try the last 2 youtube video, one do not work and the other want me to pay $90 usd to buy the device that look like a pony prog reader writer but his one is connect to a PIC chip
The Following User Says Thank You to datacablelondon For This Useful Post:
Old 11-01-2013, 19:38   #17 (permalink)
Member: 8379
Thanks Meter: 35
My MacBook pro is actually a 2012 model
Bought a ****sy 3.0 on ebay, program it to try all the code from 0000 to 9999 after 4 hours, it found the passcode to be 0795
I am well happy with this
Old 11-02-2013, 11:02   #18 (permalink)
Member: 2057957
what is the tool you used? i need to unlock my mid 2012 macbook pro 13"
Old 11-02-2013, 11:28   #19 (permalink)
Member: 8379
Thanks Meter: 35
I don't think I am allow to give the name here because the forum admin has xxx out the name in my last post.
Old 11-04-2013, 01:57   #20 (permalink)
Member: 1551570
could you please PM the info and maybe a quick how to? i have macbook pro that is just being a paper weight. please, and thank you !
The Following User Says Thank You to s3baz10 For This Useful Post:
Old 11-04-2013, 02:27   #21 (permalink)
Member: 8379
Thanks Meter: 35
The device is appox £50 pm me if you want to know how to buy one
Old 11-09-2013, 21:33   #22 (permalink)
Member: 8379
Thanks Meter: 35
You can see this device on you tube
https://www.youtube.com/watch?v=QPxDUYB8t7E
Old 11-30-2013, 09:56   #23 (permalink)
Member: 1895423
hi, i have a macbook pro 13" a1278, i don't have efi password , just have user password and i would like to clear all .
how does it do?
thank you
Old 11-30-2013, 11:21   #24 (permalink)
Member: 8379
Thanks Meter: 35
You cannot hack the user password, you can only format the hard drive and re-install OSX.
After format the MacBook will ask you for efi ( bios ) passcode ( 4 digit )
Old 11-30-2013, 21:59   #25 (permalink)
Member: 1895423
how i can format the hard drive .? with an other computer ?
Old 11-30-2013, 22:44   #26 (permalink)
Member: 8379
Thanks Meter: 35
You can do it with Disk utility once you have the EFI passcode or take out to format on another computer
Old 12-12-2013, 11:44   #27 (permalink)
Member: 2082774
Bypass Mac Firmware Password
1) Shut down your computer
2) Remove the battery
3) Slide one of the levers (it doesnt matter which one) to the left. This will release the RAM
4) Gently wiggle the RAM card out and put it aside, you will put it back later
5) Boot up the computer while holding COMMAND+OPTION+P+R (this resets the parameter ram)
6) Wait for the startup chime to sound 3 times
7) Release the keys and shutdown the machine once you reach the login screen
Replace the RAM module and slide the lever back while pushing it in until it does not wiggle anymore
9) Now if you boot up the machine you should bypass the Mac firmware password.
You can now use the machine as usual, boot from an external drive, or whatever else.
Does that also work for macbook air model A1466
Old 12-12-2013, 12:19   #28 (permalink)
Member: 8379
Thanks Meter: 35
This method is good if you have a Mac made before 2010
Old 01-23-2014, 17:46   #29 (permalink)
Member: 2103360
Where I can find the removal EFI password tool, for a Macbook Pro Mid 2012?
The Following User Says Thank You to Gibson_uk For This Useful Post:
Old 02-06-2014, 04:11   #30 (permalink)
Member: 2122301
efi password
Purchased a macbook pro off craigslist(never do that again) turned it on and it looked good but when i got it home and connected to my internet it locked up on me and asked for a 4 digit pin that i didnt have so upon searching google i found out it was an efi/icloud lock I thought i had a $600 paperweight until another google search uncovered a solution. I sent my machine to a computer repair spot in NJ which I found at ******cityrepairdotcom and when i got it back it was like new. Thank goodness for them so if u run into this problem I suggest you give them a call 2012221055
The Following User Says Thank You to aries70 For This Useful Post:
Page generated in 0.20458 seconds with 9 queries
