Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Bada Platform
Bada Platform S8500, S8530, S7230, S5253, S5230, S5330, S5380, S8600, S7250, S5333, S5750
Old 04-01-2014, 13:29   #1 (permalink)
Member: 644224
Thanks Meter: 70
How to Android Samsung S8600 WAVE3
Samsung S8600 WAVE3 Hang on Logo. So I want to Install Android version. How to Android Samsung S8600 WAVE3 ?????
Br,
shemul
Old 04-09-2014, 12:18   #2 (permalink)
faizafirdous's Avatar
Member: 1281866
Thanks Meter: 330
i also want to install android on wave 3 is it possible
Old 04-09-2014, 12:27   #3 (permalink)
Member: 729685
Thanks Meter: 2
u cant change bada software into android not yet anyone did tell us we can make more bingo many pcs are waiting thnx
Old 04-10-2014, 12:24   #4 (permalink)
Member: 1387849
Sonork: 100.1623264
Thanks Meter: 15
Android port for Samsung WAVE3 (GT-S8600)
Hi all.
This thread only for developers! Only! No questions - when?!!!!!!!
This is my attempt to porting android on S8600.
I wrote custom bootloader - emmcboot, based on codeaurora LK-bootloader.
Bootloader is successfully start, work and trying to load android kernel from internal
microsd card.
Now is unsuccessfully,after type message "Uncompressing Linux... done, booting the kernel." device rebooted or stopped.
[370] Panel is power on
[370] Display initialized
[370] Display logo
[370] Waiting for modem+++
[370] Waiting for modem: Done
[370] smem ram ptable found: ver: 0 len: 6
[370] scratch: 0x8000000
[370] Starting in SD mode!
[370] SD_DETECT pin : 0x0
[380] Initializing MMC host data structure and clock!
[380] Error No. 2: Failure Initializing MMC Card!
[400] Decoded CID fields:
[400] Manufacturer ID: 27
[400] OEM ID: 0x5048
[400] Product Name: SD16G
[400] Product revision: 3.0
[400] Product serial number: 7C88FF04
[400] Manufacturing date: 2 2012
[410] Serial number -[410] serial number:
[410] partition misc doesn't exist
[410] error in emmc_recovery_init
[580]
kernel @ 208000 (4132528 bytes)
[580] ramdisk @ 1200000 (175204 bytes)
[580] cmdline = 'console=null androidboot.hardware=qcom user_debug=31'
[580]
Booting Linux
[580] smem ram ptable found: ver: 0 len: 6
[580] booting linux @ 0x208000, ramdisk @ 0x1200000 (175204)
[590] cmdline: console=null androidboot.hardware=qcom user_debug=31
source code for lk-bootloader for S8600:
https://github.com/Oleg-k/LK_BOOT_S8600
To build for S8600, type: "make -j4 s8600 EMMC_BOOT=1"
Also, i got memory dump, stage - after load oemsbl and before loading my bootloader.
as we see, oemsbl decompress and load apps_compressed.bin into memory,
starting at 0x200000.
https://www.dropbox.com/s/5wf6dp5gfg...DUMP_128MB.rar
And for for understanding boot process on MSM7x30, read this:
http://tjworld.net/wiki/Android/HTC/...ss#BootProcess
The Following User Says Thank You to i_4_u89 For This Useful Post:
Old 04-15-2014, 02:12   #5 (permalink)
Member: 420658
Thanks Meter: 211
1 bigger problem is to play without JTAG...
xda-developers - View Single Post - Android port for Samsung WAVE3 (GT-S8600)
appsboot.mbn is the mandatory file, what oleg_k replaced via JTAG (RIFF Box for instance).
I have now found way to kill Bootchain via Multiloader + osbl.bin...
Then result is this:
http://forum.gsmhosting.com/vbb/f818...e-3-a-1610764/
There are several infos about QPST and eMMC app...
Maybe in combination with these files from S8600:
http://forum.gsmhosting.com/vbb/10009255-post3.html
1 Tut as example:
[Tutorial] Revive dead Karbonn A9+/CM Flare after JB update - xda-developers
For me not solved yet, to find correct files/settings for QPST eMMC app.
But this would be big step forward, if someone knows how to write something with Qualcomm Emergency DL... to S8600.
Best Regards
The Following User Says Thank You to adfree For This Useful Post:
Old 04-26-2014, 08:59   #6 (permalink)
Member: 420658
Thanks Meter: 211
Is someone able to tell me. How oleg_k startet kernel?
It seems different way as on S8500/S8530...
zImage to "Phone memory"...
I9001 for instance start kernel at 0x9000000...
S8600 apps_compressd is loading from 0x8000000...
I have tried few JTAG dumps...
I9001
I8150
I8350
Sometimes I can see something on Display... like Samsung Logo or DL Mode ... Flash Tools detect device... but here it seems f. Security prevent more success...
Best Regards
Old 05-01-2014, 18:11   #7 (permalink)
Member: 420658
Thanks Meter: 211
Is somebody here, with S8600 + solder skills + JTAG + willing to try few things?
Please.
If you have JTAG + S8600 you could write here or contact me via PM or in XDA forum.
At the moment I need someone to confirm my "tests", maybe I do something wrong...
In other words. S O S
Thanx in advance.
Best Regards
Old 05-14-2014, 17:48   #8 (permalink)
Member: 420658
Thanks Meter: 211
I am closer to write appsboot/emmcboot to S8600... without JTAG.
This means NOT Android port is finished nor started...
Best Regards
Old 06-16-2014, 04:20   #9 (permalink)
Member: 420658
Thanks Meter: 211
After QPST I found another way to write oleg_k EMMCBOOT aka appsboot into S8600...
This time much easier...
EMMCBOOT from oleg_k is "injected" into apps_compressed.bin from XXKJC:
apps_EMMCv1
For more info:
Android port for Samsung WAVE3 (GT-S8600) - Post #347 - XDA
Simple use Multiloader + my modified apps_compressed.bin and you can see oleg_k Low Kernel running...
Nothing more, because Android Kernel is missing...
At your own risk and only for study...
This means you could inject ca. 340 KB own Code into apps_compressed.bin without killing integrety...
Best Regards
Old 07-15-2014, 05:40   #10 (permalink)
Member: 420658
Thanks Meter: 211
Little progress...
Android port for Samsung WAVE3 (GT-S8600) - Post #493 - XDA Forum
Video about S8600 booting I9001 kernel... before reboot.
Android port for Samsung WAVE3 (GT-S8600) - Post #506 - XDA Forum
Achieved with this I9001 dump from 0 - 0x0900 0000... and mixed with Samsung_GTI9001_2GB.rar
For now only with JTAG...
In theory via QPST possible... but dangerous because whole EMMC partition layout is nuked by I9001 stuff...Will try to mix with 4 GB dump... maybe longer start...Best Regards
Old 08-07-2014, 04:16   #11 (permalink)
Member: 420658
Thanks Meter: 211
Little progress:
Android port for Samsung WAVE3 (GT-S8600) - Post #655 - XDA Forum
If someone with S8600 and JTAG have too much time...
He could help me...
This is also via QPST and without JTAG possible...
But more dangerous, as you have no chance without JTAG to repair Boot or other stupid Firmware ""crashes""...
For study...
Best Regards
Old 08-28-2014, 03:09   #12 (permalink)
Member: 420658
Thanks Meter: 211
mXT224
mXT224E
mXT224S
Please, I need help to identify Touch used on S8600...
I found only this Pic... better then FCC Pic, but I can NOT see all necessary infos...
Thanx in advance.
Best Regards
Page generated in 0.22725 seconds with 9 queries
