Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Bada Platform
Bada Platform S8500, S8530, S7230, S5253, S5230, S5330, S5380, S8600, S7250, S5333, S5750
Old 10-01-2013, 06:02   #1 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 183
samsung s5270k blinking or restart 100% working solution is ready
samsung s5270k blinking or restart 100% working solution is ready first download flasher Hotfile.com: One click file hosting: S5270K_Flash_loader_7.5.3_CSC_v0.4_Lite.rar Samsung S5270K Ch@t 527 Firmware Update Steps: - Make sure that the device battery is fully charged. - Turn the phone off. - Take out its SIM-card and memory card too. - Inside the Flash Loader folder you will see: Sunstone_V5_00_0_1_WHQLed.zip extract it too, Then click on Setup.exe and install the USB drivers. - Run bfloader.exe program. - Click on SET Model button to select: S3770_Telesto_Setting_v00.mdl - To select the Main flash file check the Main box, Then click on Browse button and select: S5270Kxxxxx.ptt - Click on Main Partition Table button , Then click OK at the new Window. - To select the CSC flash file check the CSC box, Then click on Browse button and select: S5270KOxxxxx.ptt - Click on CSC Partition Table button button, Then click OK at the new Window. - Select USB option at Communication Settings. - Remove Battery from phone and insert it again. - Click on START button. - With battery inside the phone Press and Hold 2 + 3 Keys then plug the USB cable into it. - Windows will detects the device and installs its needed drivers. - When Flash Loader program detects your phone it will start to install the firmware files into your device. - After Flash Loader finishes his job you will see "Slot freed for new download" - Disconnect the USB cable from it. plz add this setting in main partion all will be ok but imei will be 00000000000 Uploaded with ImageShack.us when u flash with this procedure rebuild imei 100% tested solution u can also use for s5610k
Old 10-01-2013, 06:13   #2 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 183
use this setting plz 100% ok but imei will be 000000000000 Uploaded with ImageShack.us
The Following User Says Thank You to anil.prajapati For This Useful Post:
Old 10-08-2013, 07:20   #3 (permalink)
Member: 1256955
hi
how to write imei s5270k?
Old 10-08-2013, 11:27   #4 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 183
with hwk 100% ok
imei write in 1 sec with hwk
The Following 2 Users Say Thank You to anil.prajapati For This Useful Post:
Old 01-14-2014, 06:48   #5 (permalink)
Member: 1899850
Thanks Meter: 11
i tried flash with flash loader but it's hard to connect..which button is really true??
Old 01-14-2014, 07:05   #6 (permalink)
Member: 181829
Thanks Meter: 119
salam,
tested by my , imei ok !
Old 02-09-2014, 09:38   #7 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,109
Here Flash_loader_7.5.3_CSC_v0.4_Lite - Download - 4shared - vaghubha sodha
Bro:- Palash Ahammad
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 02-11-2014, 11:49   #8 (permalink)
Member: 686500
Thanks Meter: 12
s5270k i tried the above mentioned method,no result.s5270k e2p file i searched.not available.samsung masters how can i solve this blinking issue for s5270k?thanx in advance.
regards
jithesh.
Old 10-10-2014, 06:31   #9 (permalink)
naveen_kool's Avatar
Member: 1314849
Sonork: 100.1659284
Thanks Meter: 8
not solve phone is still blinking
Old 10-10-2014, 17:08   #10 (permalink)
Member: 2271700
how to repair imei gt s5270
my phone flash successfully but how to repair imei........
Old 10-18-2014, 16:20   #11 (permalink)
Member: 1314849
Sonork: 100.1659284
Thanks Meter: 8
need Flash tool for s3600
Old 01-04-2015, 11:37   #12 (permalink)
Member: 2279412
Thanks Meter: 6
binary crashed helpppp
Page generated in 0.19622 seconds with 8 queries
