Bada Platform S8500, S8530, S7230, S5253, S5230, S5330, S5380, S8600, S7250, S5333, S5750 |
06-23-2013, 15:41 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | Quote:
This is not enough info... If RIFF Box shows this... Then damaged Blocks on 512 MB OneNAND... On my test S8500 I have 1 damaged block... I can ignore it... On my test S8530 I have 3 damaged blocks... I can ignore it... Without JTAG it is also possible to check damaged Blocks... if Bluescreen... If Debug Level Mid or High... Then check text like this: Code: Bad Block Information: nNumBMPs : 0 nAge : 0 Run Time Bad Block Occurred : Init BMPs = 2, Current BMPs = 0 Perfect would be 0... 1 Block is 256 KB... length 0x40000 2 x 256 KB = 512 KB less, if 2 Blocks damaged... Best Regards | |
