08-18-2014, 22:41 | #1 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2122523 Status: Offline Thanks Meter: 1 | iPhone 4s Sprint, ios 7.1.2 , searching for network I tried to unlock it with rsim mini 9.1 and rsim 9 pro. I also installed the C Patch from isamteam repo but no luck. The phone keeps searching for network even without sim. Is it because of the ios 7.1.2? I have another sprint iphone 4s running 7.0.4 with rsim mini working perfectly. Which is the problem? If it is because of ios 7.1.2 which one should I buy? Thank you |
08-19-2014, 07:48 | #3 (permalink) |
Member: 2122523 Status: Offline Thanks Meter: 1 | Hello and thanks for your answer! I did it and still nothing.. The odd thing is that if I switch to manual select carrier, i can see all greek carriers and I can select anyone of them. No matter which sim I use. But even then, searching is there. My carrier is 16.1 if this helps. Thank you! |
08-29-2014, 19:03 | #11 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2248859 Status: Offline Thanks Meter: 0 | Hello, somebody can fix this? I have the same problem, my iphone is a 4s sprint, i try to giunlock with rsim 9 pro, but no gives signal, only said "Searching" my ios is 7.1.2, thanks a lot and sorry for my english. |
