04-03-2014, 20:39 | #1 (permalink) |
Junior Member Join Date: Apr 2014 Location: México
Member: 2160385 Status: Offline Thanks Meter: 0 | R SIM MINI EXTREME Not working with 256kb LTE SIM I downloaded the patch but it is not working. Any advice? |
04-03-2014, 21:02 | #2 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2094769 Status: Offline Thanks Meter: 76 | Some members were reporting success using the Rpach on iphone 5s and 5c ATT ios 7.1 but never heard about LTE or 4G being success yet so I am just guessing that is something which could be achieved using the new chip mini2 if and if it's true. |
04-04-2014, 16:53 | #8 (permalink) | |
Member: 2160385 Status: Offline Thanks Meter: 0 | Not LTE speeds Quote:
I'm not trying to get LTE or 4G speeds, i'm saying my SIM CARD says on the label it's a 256kb SIM with the letters LTE 4G on the front. My question would be if I need to get a lowe KB sim in order to make it work or if there is any workaround. | |
04-05-2014, 01:00 | #12 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | So what happens when you insert the chip with your nano sim card ? do you see the sim application in under phone if yes go to select carrier then enter imsi then 3104101 accept restart but remember first you need to install the iroostool and open it and force 2g first. let me know the conclusion. Really I don't recommend rsim mini for iphone 4s so I don't know why would you buy this rsim mini since we have the rsim air which works as a champ for iphone 4s. |
04-05-2014, 01:18 | #13 (permalink) |
Member: 2160385 Status: Offline Thanks Meter: 0 | This is what it shows on the "Phone" Tab My Number "Unknown" Contact photos in favorites Slided ON CALLS Respond with text Blocked Change voicemail password SIM PIN TAB. And I got this rsim mini+ extreme because i trusted someone more than I should have. (And because ima noob in iphone unlocking) that's all. |
04-05-2014, 01:40 | #14 (permalink) | |
Freak Poster Join Date: Apr 2014 Location: iCloud
Member: 2160880 Status: Offline Thanks Meter: 17 | Quote:
R-SIM Air we have tested as well and it delivers wonderful results, a bit more expensive though and got us with Activation Required issues. Nothing bad, just extra work. Cheers, | |
04-05-2014, 01:41 | #15 (permalink) | |
You should see an option there saying "SIM Applications". | |
