Call from contacts doesn't work Imagine one contact added in contact list. If I configure this contact with XXXX-XXXX number, I can't make a call (my provider say invalid call) and when it call me I see only numbers. If I configure this contact with 00 55 41 XXXX-XXXX (international syntax), I can't make a call (my provider say invalid call) and when it call me I see his name. When I configure both syntax, I can see his name when it call me, but I can't make calls from contact. To make a call, I need copy from contacts XXXX-XXXX number and paste in the dialer or I have to write directly in the dialer. I tried reset network and put SIM without RSIM to configure BR format, but didn't worked. On the Google I saw how to fix this problem, but need Jailbreak. I think RSIM doesn't recognize my region and set international syntax or roaming mode or set CN configuration. How can I fix this? :confused: Thanks |
::::::::::::::: Flash Yr phone software & 100% will work. (: ::::::::::::::: |
I flashed with patch 5.0.0.0 and didn't worked =( |
I got the same issue when I installed the final patch. I have to restore to get it back. However, it is really annoying since I have to get Rsim8 worked again |
So it doesnt work too for you? |
But 2g and 3g work flawless? |
br cdmagsm03 |
So I prefer stay with 3G, but I think it must have a fix. Ideas? |
Any idea to fix this? |
May anyone have new suggestions? |
R-SIM iPhone 5 and 4S GSM/CDMA Unlocking and Activation ,GEVEY UNLOCK,GPP UNLOCK , iF USE THIS PATCH" For R-sim, 3G/4G Nano 128K USIM +iphone 4s/5 universal 3G activation code programme" all is ok |
I have SMS, calls and 3g working, but I didn't get calls from contact list... my gsm operator say: "wrong format". Because of that, I'm using "cobook" app to make calls from my contacts, but I need to use original dialer. It's more fast than cobook app. Note: I have to use ir0setool to 3g work... RSIM3 app don't solve this issue! ...I'm thinking to sell rsim8 chips in my country, but if rsim8 doesn't work as well, i won't sell... |
