11-02-2013, 15:00 | #4 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2034405 Status: Offline Thanks Meter: 0 | yes, dont buy any rsim now, this rsim isnt work for many carrier on ios 7.x.x. even we use patch isnt not working too. wait until miliky and friend give us information that rsim can prefectly used on ios 7.x.x in all carrier (especially from sprint) |
11-02-2013, 15:09 | #5 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 379713 Status: Offline Thanks Meter: 55 | I can say THERE IS NO SIGNIFICANT DIFFERENT between the all types of rsim. The result will be depends on carrier , ios version you have and the simcard you are using. If you are using sprint/cdma gsm iphone ios 6 and you have 64k and below simcard, i guess it will be fine. Ther result even better if you have gsm only iphone. The problem is started at ios 7 and cdma gsm iphone, mostly on sprint. You did not stated what carrier, version iOS and type of your simcard. |
11-02-2013, 18:11 | #7 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1729854 Status: Offline Thanks Meter: 31 | There is no difference between R-SIM 8, R-SIM 8 GOLD, R-SIM 8+, R-SIM 8 PRO and R-SIM 9 PRO. All work same way since R-SIM 8, absolutly no difference, all others advantages published by owner are only false publicity. (all can use iR0seTool and PC Patch software, this apply also to other brands of turbo sims) The only irrelevant difference between R-SIM 8/8 Gold and R-SIM8+/8 Pro/9 Pro is that the last ones have a better iPhone 5 Sim tray. Yes, they charge more money for changing a SIM tray LOL, but they advertised some false improvements like 128k sim compatibility to make think customers got a "better product" |
11-02-2013, 23:08 | #10 (permalink) |
Registered User Join Date: Aug 2009 Location: usa
Member: 1102531 Status: Offline Thanks Meter: 3 | R-sim 8+ worked on iphone 4s from sprint version 6.0.1 didnt work on verizon 4s 7.0.2 R-sim 9pro worked on both! 3G/SMS worked on all 3 scenaries |
The Following User Says Thank You to DJ Lovers For This Useful Post: |
11-03-2013, 14:40 | #12 (permalink) |
Member: 379713 Status: Offline Thanks Meter: 55 | In hardware,it might be. But in rsim 9, there is a differences inside the chip. Read this data already with arduino board. Perhaps you already ask your friend about this (i read your recent post). So, i still believe rsim 9 have the most compatibility. But again, its all depends on your carrier, ios and simcard in your country. |
